BEKO WDR7543121W Sudden No Power
Home Forums Public Support Forums Help And Support Washing Machine Help Forum BEKO WDR7543121W Sudden No Power
Viewing 15 posts - 91 through 105 (of 132 total)
  • #470419
    thats the inveter pcb for the motor, the main power board is the other one
    Joseph Kaz
    lol can’t believe I did that. Whereabouts exactly is the PCB located then?
    Also anyone able to identify this connector type for me given it needs re-terminating?
    #470421
    its in another black case at the the bottom rear
    as for he terminal
    https://cpc.farnell.com/te-connectivity-amp/156666-1/receptacle-faston-r-a-awg16-14/dp/CN19519?mckv=sGnVvFeqw_dc|pcrid|224645161149|kword||match||plid||slid||product|CN19519|pgrid|45968746254|ptaid|pla-890150846536|&CMP=KNC-GUK-CPC-SHOPPING&s_kwcid=AL!5616!3!224645161149!!!network}!890150846536!&gclid=EAIaIQobChMIzo_67MmA8wIVuBoGAB25zAjGEAQYAiABEgKOLPD_BwE
    but make sure you get the correct crimper and cut back to clean wire even if you have to extend it
    you will also need
    https://shop.ukwhitegoods.co.uk/washer-dryer-thermal-cut-out
    but get it working again first as this will only stop the dryer
    HTA
    Hi Dave,
    Just an update.
    I bottled out on testing of the board voltages as I felt it was out of my skill set.
    We ordered a new Main PCB ( https://www.espares.co.uk/product/es1777863/washer-dryer-main-pcb ) from espares which arrived on Saturday (great service).
    Fitted new PCB and (drum roll) NOTHING! Machine was still as dead as a dodo!
    We were resigned to getting a new machine but I decided to take the top of the machine off (not sure why TBH!) and have a look at the front panel control board. I took the top loom connector off the PCB and then decided that a new machine was indeed the order of the day. I reattached the connector, plugged the machine back in and it powered up!!!
    I swapped the ‘new’ PCB for the ‘old’ one and all worked fine!!!
    I am frustrated as I cannot explain how I ‘mended it’!
    Anyway ‘new’ PCB on way back for a refund and all sorted.
    Many thanks for your kind help and patience Dave – I am very grateful
    BTW – the new PCB has no D7 diode any more, they have obviously changed some of the design on this board? Please find attached a pic of the new PCB: –
    https://www.dropbox.com/s/hmwio6jo2e1pghh/New-PCB-Layout.jpg
    #470423
    looks like D6 is doing same job but loads bigger
    Joseph Kaz
    Hi all,
    An update from me. I swapped out the diode and everything is working again. Thanks you so much everyone!
    #470425
    Vic11
    My first post. Also had power problems with my washer dryer. Replaced Diode and all is well. Thanks to previous posters for info. Beko not interested when contacted them but this is a systemic issue so they should take ownership. Just wanted to add my voice to show it is a common problem and easy to fix. Either replace PCB (£55) or just the diode diode if you have the skills (£2)
    #470426
    I have seen pictures of the replacement boards and the diode is much bigger. so they know its a problem
    Sally Anne
    [h=2]BEKO WDR7543121W[/h] Has anyone sought a remedy under consumer protection rules?
    #470428
    JustC
    Just want to say, thank you Dave! I found the forum by accident while searching for a solution to the problem, and when I saw that everyone was having the same problem, I knew I had to try even if it didn’t work. And, yeah … it worked! So once again, thanks Dave for the solution!
    #470429
    Audie
    Big Thank you Dave. Same problem with my Beko washer/dryer. Changed the D7 diode. Feeling very chuffed with myself. Working perfectly.
    #470430
    ZeeGerman in NZ
    electrofix wrote:left hand side of the board
    looks like D7 its a diode
    check if its short circuit
    this seem to be an up and coming problem
    Brilliant ! Easy fix for me as well here in NZ ….D7 was kaputt and didn’t let me switch machine one ..
    ‘Had to Thanks Dave !
    #470431
    Smithy39
    Had same issue with WDR7543121 Washer / Dryer where it would not turn on.
    Replaced the D7 diode and it came back to life but after returning it into position (moved a couple feet) it would then not re-energise, but did beep when power was turned on at the socket.
    Thought other issues with the main board so replaced the full board and same thing happened, worked initially on first power up but then wouldn’t when returned back into place.
    Is there anything i should check before giving up and getting a new machine?
    #470432
    i would go and chack all the plugs are in properly and secure
    Smithy39
    Morning Dave,
    thanks for the response! I’ve checked all the plug connectors are secure and everything seems fine, removed and re-installed to make sure but still same issue with the beep and no display.
