Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › candy alise 105 changing bearings
- This topic has 112 replies, 14 voices, and was last updated 20 years, 11 months ago by
yurtesen.
April 24, 2005 at 1:15 pm #132159
yurtesen
ParticipantRe: candy alise 105 changing bearings
Penguin45 wrote:
6204ZR and 6203ZR bearings with rubber membrane are water resistant. They are not waterproof.However I think RSH versions are, since the specs say that they have good high pressure water exclusion. But the pressure near the shaft is not much in a washing machine think.
Evren
April 25, 2005 at 4:35 pm #132160yurtesen
ParticipantGot skf explorer watertight sealed bearings…
http://master.titol.fi/~yurtesen/CIMG0890.JPG
http://master.titol.fi/~yurtesen/CIMG0891.JPGI will soon get the part to fix the problem with the shaft seal. Rather costy, but not as much as a new drum. Costs 16euro.
Updates are yet to come. Stay tuned.
Evren
April 25, 2005 at 9:54 pm #132161eastlmark
ModeratorRe: candy alise 105 changing bearings
cant wait….. π
April 27, 2005 at 3:28 pm #132162yurtesen
eastlmark wrote:cant wait….. π
ΓΆΓΆ, why cant you wait? and why a sad face?
I cant wait too but the parts are refusing to arrive :p Have to be patient really. Post is working slow!
April 27, 2005 at 3:40 pm #132163Dave_Conway
The seal left here today Evren :tup:
April 27, 2005 at 4:18 pm #132164yurtesen
Dave_Conway wrote:The seal left here today Evren :tup:
Great news, but I am still missing one part. The part which will go over the shaft seal :p But it will come tomorrow or friday.
Thanks for everything. I hope to submit success next week about putting the machine back into 1 piece again π
April 27, 2005 at 4:20 pm #132165Martin
…thinks….”I wonder if Dave sent it out on Finnair?”
April 27, 2005 at 4:58 pm #132166yurtesen
ParticipantI dont think it does matter as long as it arrives in 1 piece and in less than 10 years time π
April 28, 2005 at 9:52 am #132167streetlighter
π― π― π― π― π― π― π― π― π― π― π―
I thought I had probs getting the t40 bolts out of a ind wd12.April 28, 2005 at 10:46 am #132168yurtesen
streetlighter wrote:π― π― π― π― π― π― π― π― π― π― π―
I thought I had probs getting the t40 bolts out of a ind wd12.π lets hope this machine’s problems will end for a long long time once it is closed :p
May 2, 2005 at 3:49 pm #132169yurtesen
ParticipantI have received the oil seal but it is little bit different size than the original.
The original has
30 53/60 10/13
The one I received from Dave is
30 52/60 11/15So it is loose when fitted to back plate. The drum side is little bit bigger also but thats not a big problem I guess. So what are the suggestions now?
Evren
May 2, 2005 at 5:39 pm #132170Dave_Conway
Evren, why do you post here and PM me with exactly the same question ?
Go back to the very beggining of the thread and take the advice first given, give up !
I for one am quite tired of this tale now to be frank.
May 2, 2005 at 6:35 pm #132171Penguin45
Just plaster the back of the seal with silicon sealant and fit it. Wait until it’s set and reassemble.
P45.
May 11, 2005 at 4:57 am #132172yurtesen
ParticipantThanks for everybodies’ suggestions on this topic.
I have received the right size seal and installed it.After few washes, nothing is leaking and everything seem to be working in perfect order.
How can one know if the belt is too loose or too tight?
I have realized that when the machine is drying the water goes in and gets divided to 2 places. Some goes to the condenser and some goes to washing powder box then directly to the water pump. Obviously the water in condenser is taking off the water vapour from the air passing by but what is the purpose of the water going to washing powder box?
EvrenMay 11, 2005 at 7:22 am #132173Martin
Participantyurtesen wrote:How can one know if the belt is too loose or too tight?
It should have about 2 cms play π
yurtesen wrote:I have realized that when the machine is drying the water goes in and gets divided to 2 places.
The Candy Alise 105 was not sold in the UK (therefore no direct equivalent to compare) but those Alise models that were produced for the UK market did have a ‘vent pipe’ connected between the condenser unit and the water inlet valve. The vent goes to the dispenser but the water should not flow in that direction as it acts only as an air break.
