Indesit DI620 – Please help :)
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Indesit DI620 – Please help :)
Viewing 15 posts - 46 through 60 (of 90 total)
  • #234860
    Re: Indesit DI620 – Please help 🙂
    If you have a DI620 then you should have the heating element that is visible inside the tub, under the lower spray arm. This one does fail but nowhere near as much as the internal, tube type element.
    Access to the heater terminals are from underneath, mains plug out, tilt over on left hand side from front onto several large towels and remove base. You will need a meggar or suitable multimeter to check the element. Chances are that it will be the module though.
    silentwitness
    Ok, thanks for that. If the heater is alright, am I correct in thinking the part number I need for the board is C00143222?
    Many thanks
    #234862
    LJDomestics
    scooterck wrote:Hi,
    Sorry I didnt come back to confirm fix for dishwasher, it was the control pcb.
    I honestly didnt think it would fix it, cos there where no signs of damage and all components tested okay.
    But there you have it, you guys rock !!!!!!!!!!!!
    Thank for all your help and saving me the dreaded Indesit call out charge 🙂
    Thanks so much !!!
    For future reference u could always call your nearest repair centre for the area your situated.. or ask around, there is always someone u know who will of had dealings with a good repair centre.
    Theres always a standard callout charge with major manufactures and from many customers own mouth they are quite high, sometimes half the price of actually replacing the product with a new one these days and a brand new 12 months warranty thrown in.
    Agood local repair centre will more than likely in many situations be able to diagnose and repair your appliance for a good bit less that some manufactures actual initial call out charge.
    #234863
    silentwitness wrote:Ok, thanks for that. If the heater is alright, am I correct in thinking the part number I need for the board is C00143222?
    Many thanks
    Two different boards, would need your full serial number to identify.
    silentwitness
    Great, thanks Jim. THe S/N is 70416-3026.
    Cheers
    Col
    #234865
    silentwitness wrote:Great, thanks Jim. THe S/N is 70416-3026.
    Cheers
    Col
    C00143222 is the correct PCB for that machine. If you want to risk giving it a go then an e-mail to spares@ukwhitegoods.co.uk should get you price and delivery details.
    Bear in mind that these parts are non refundable.
    silentwitness
    Thanks Jim, that’s great.
    I emailed spares@…. Apparently they’re unable to get the PCB that I need. Do you know of anywhere else that might stock it?
    Col
    #234867
    Try contacting the Indesit Company directly, it will be cheaper than ESpares thats for sure. 😉
    Last post removed.
    gandh1. Please apply for trade access before offering goods for sale to the general public. 😉
    #234869
    fritz
    I have read this thread and need a little help, I have the same problem and have tested the element, (reading of 27), so that’s okay. The next is thermostat, reading of 0.2, is this right? Or does it need replacing? I don’t want to buy a PCB if this is the problem.
    #234870
    Points towards a PCB fault. What you have tested is the safety stat, the temp control is via an NTC which is hard wired to the PCB. You would normally test a stat for continuity rather than resistance, it is a normally closed circuit safety stat.
    I have never personally changed a safety stat on one of these, lots of PCB’s and heating elements.
    #234871
    fritz
    Thanks for that, so it looks like the PCB, that;s a bit of a same, but better than doing the washing up.
    #234872
    fritz
    So I ve fitted the PCB and turned on the dishwasher I now have lights 2 and 3 constantly on and a buzzy sound when I press the programme button, any ideas?
    #234873
    fritz
    Sorted, just putting it through the first wash
    #234874
    maltheviking
    fritz wrote:🙂
    Ah so you read the fitting instructions then? :rolls:
