Neff fan oven elements
Viewing 15 posts - 16 through 30 (of 80 total)
  • #162034
    Re: Neff fan oven elements
    to what? had some last week still on that part number. now at £34.70 before discount.
    #162035
    superfix
    499003, just had some new van stock ones through 😉
    #162036
    aqualectric
    Martin wrote:Not having the benefit of the oven model number, some have had modified back panels (sheets) others had elements upgraded (new part numbers) and so on. 😉
    They are:-
    Neff U1421BOGB/01 and U1421WOGB/01
    Please come back with the info on these modified parts; thanks!!! Have had another Neff failure booked in today for Thursday. 🙄
    Should have listened to my old dad when he said “Get yourself a proper job,son!! 😆
    #162037
    Fitted a new fan motor to one of these today and notcied the fan has now got a ring of holes in it which are new, not seen one like that before anyhow. Maybe some connection with the life of the elements? Mind you the fan motors are not that reliable either.
    #162038
    gegsy
    boro wrote:499003, just had some new van stock ones through 😉
    Yep confirm that just had some through aswell 😉
    sparkey
    Been fitting these for good nine months, as yet have not had to replace one of new type.
    I think the holes help to keep the shaft cooler thus not ‘cooking’ the front motor bearing. (pardon the pun)
    Regards
    Sparkey
    #162040
    Dave_Conway
    Are these holes drilled all the way through the fan blade or just semi as normally they are just made to balance any weight imperfections to stop vibration ?
    #162041
    sparkey
    they are drilled right through the fan blade, six if I remember correctly approx 5mm dia., (too cold to go and look in the van right now)
    Regards
    Sparkey
    #162042
    Just recieved a consignement of elements from BSH today and they are still 493065’s Seem us mere trade accounts are using up the old stock.
    #162043
    Dave_Conway wrote:Are these holes drilled all the way through the fan blade or just semi as normally they are just made to balance any weight imperfections to stop vibration ?
    The fan on the bosch oven I changed the half moon element on yesterday had holes in it. I was rather glad of them as well. The top fixing screw for the element is behind the fan. 😥 I had to heat the fan with my blow lamp to loosen it, then poke my long nosed pliers through the holes so that I could pull off the fan without burning my fingers.
    #162044
    Bryan
    eastlmark wrote:to what? had some last week still on that part number. now at £34.70 before discount.
    Don`t know how much discount you guys get from BSH but these elements(493065) are £25:10+vat from Masterpart , but out of stock unfortunately.
    You might save yourselves a couple of quid.
    Bryan
    #162045
    gegsy
    iadom wrote:The fan on the bosch oven I changed the half moon element on yesterday had holes in it. I was rather glad of them as well. The top fixing screw for the element is behind the fan. 😥 I had to heat the fan with my blow lamp to loosen it, then poke my long nosed pliers through the holes so that I could pull off the fan without burning my fingers.
    Jim
    If you take nut and lock washer off then grip shaft 😯 with pliers; turn fan blade at same time round and round and 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time the fan will pull off.
    Greg 😉
    #162046
    gegsy wrote:
    Jim
    Greg 😉
    This one was the 1{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} 😉 If I had held the shaft with the force needed I would have damaged the thread, it was stuck tight all right.
    #162047
    gegsy
    In that case get a long pozi and get behind fan by pressing down on it and remove that soddin screw 😆 .
    When replacing dont bother replacing that top screw as that element aint goin anywhere. Done loads no problem doesnt bend shaft etc 😉
    PS only seems to jam on the built under double ovens 😕
    #162048
    Bryan
    I put a small squirt of WD40 on the shaft/fan , leave it for 5 minutes , then as you say Greg hold the shaft and turn the fan a few times 💡 .
    Bryan
