Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Neff fan oven elements
- This topic has 79 replies, 29 voices, and was last updated 20 years, 2 months ago by
aqualectric.
November 12, 2009 at 1:35 pm #162079
fasetester
ParticipantRe: Neff fan oven elements
any one have any thing to say about this oven element thanks fasetester. 🙂
November 12, 2009 at 1:51 pm #162080Martin
fasetester wrote:any one have any thing to say about this oven element thanks fasetester. 🙂
What, over and above what’s been said already in the last 4 pages Fase? What more needs saying anyway? 🙂
November 12, 2009 at 2:27 pm #162081adv
ave started fitting genuine from bosch. seem to last longer dont no why tho. its same material.aint it ? as pattern ones?
November 12, 2009 at 2:30 pm #162082fasetester
thanks martin for the reply then this post apply to most fan oven elements not just the neff.
November 12, 2009 at 2:59 pm #162083Martin
fasetester wrote:thanks martin for the reply then this post apply to most fan oven elements not just the neff.
That may well be the case Fase I’m afraid. 🙁
So far though, touch wood, I haven’t had any probs with genuine Lux elements funnily enough. Though, having said that, I expect the phone will ring at any moment from someone I’ve fitted one to recently! :rolls:
November 18, 2009 at 10:23 pm #162084roly16
I fitted one of these elements today and have some good news and some bad news for you. Which do you want first?
November 18, 2009 at 10:49 pm #162085iadom
ModeratorRe: Neff fan oven elements
Errr, well having just watched the cheating French B******s beat Ireland with a blatant handball from Tierry Henry ( once an Arsenal cheat, always…) I would like the good news please Geoff.
November 18, 2009 at 10:52 pm #162086roly16
Well, I don’t know anything about that sort of stuff but here’s the good news:
The fan came off easily.
November 18, 2009 at 11:09 pm #162087leavemetogetonwithit
Go on. Why did you need to take the fan off?
Mike.November 18, 2009 at 11:22 pm #162088iadom
roly16 wrote:Well, I don’t know anything about that sort of stuff but here’s the good news:
I’m guessing the new element was duff. ❓
November 19, 2009 at 12:38 am #162089Penguin45
Because the top retaining screw is blocked by the fan.
Roly will tell us that the new one ran for 5 minutes then went “pop”.
November 19, 2009 at 12:49 am #162090leavemetogetonwithit
Only ever did one of these. Years ago.(Genuine, still going!) Don’t see many Neff round ‘ere.
Mike.November 19, 2009 at 9:55 am #162091roly16
Penguin45 wrote:Because the top retaining screw is blocked by the fan.
Not quite that bad. The fan came off easily because the old element (Connect) had only been on for 5 months. The one before that (Qualtex) had only been on for 1 month. 😥
November 19, 2009 at 7:25 pm #162092EFS
When the fan just absolutely won’t come off I drill a hole in the fan to access the screw.
Then drill an identical hole on the opposite side to balance the fan.Makes the job easier on the return visits too 😉
Steve
November 28, 2009 at 8:33 am #162093walnut
Cowboy tip of the day,
When I started back fixing cookers 5 yrs ago I got lots of callbacks from Neff/Bosch ovens.
If its a Neff 2 loop that keeps going down then I would fit a Zanussi 3 turn.If its the 1/2 moon element I always remove the centre bracket, sprise the element apart to give a bigger gap, put some nuts as spacers between the back panel and rear wall.
Not been back to a neff for 2yrs, happy days. -
