Neff fan oven elements
Viewing 5 posts - 76 through 80 (of 80 total)
  • #162094
    Re: Neff fan oven elements
    walnut wrote:put some nuts as spacers between the back panel and rear wall.
    Wall-nuts?
    Mike.
    #162095
    mike412
    Hi folks.
    I have never had a problem getting these fans off. (I do lots of them).
    Underneath the 10mm nut is a washer with a D shaped hole in the middle to suit the shaft of the motor. I have brazed one of these washers to the end of a redundant 1/4 inch drive socket. I was able to turn the surplus material off in my lathe but it could be done by filing.
    Method.
    Remove 10mm nut . Lever off special washer. Squirt of WD. Leave couple of minutes. Using the special socket made in a socket handle, lock the motor shaft in position. Spin fan with finger ( sometimes tight at first but always gives in the end). Slide fan off.
    Where it will fit, I always use ELE9036 (CDSL) as a replacement. Not been back to one in 2 or more years.
    For the older models and the small oven I always use the genuine part, easier fit and I dont have any issues with reliabilty.
    Mike.
    #162096
    mike412 wrote:Squirt of WD. Leave couple of minutes.
    I then hold D shaft with a pair of pliers in one hand whilst loosening the fan with the other. Once the fan spins freely, ease it off the D shaft.
    mike412 wrote:Not been back to one in 2 or more years.
    There’s always an exception that proves the rule and I’m pleased to hear you’ve not had the problems the rest of us have suffered Mike.:D
    #162097
    Is this what is known as ‘being economical with the truth’ 😉 😀
    BSH elements
    #162098
    roly16
    ‘Economical with the truth’. That’s what you call it, is it? 😯
    Let’s hope that guy never gets on to this thread somehow 🙁
