Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Neff fan oven elements
- This topic has 79 replies, 29 voices, and was last updated 20 years, 2 months ago by
aqualectric.
February 9, 2006 at 7:13 pm #162049
gegsy
ParticipantRe: Neff fan oven elements
Hi Bryan
I am against WD40 for two reasons
1/ It honks for soddin ages 😆
2/ Its flammable and being so close to hot element, dont fancy my luck 🙂Greg
February 9, 2006 at 7:15 pm #162050iadom
ModeratorRe: Neff fan oven elements
gegsy wrote:
iadom wrote:
This one was the 1{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} 😉 If I had held the shaft with the force needed I would have damaged the thread, it was stuck tight all right.
In that case get a long pozi and get behind fan by pressing down on it and remove that soddin screw 😆 .
When replacing dont bother replacing that top screw as that element aint goin anywhere. Done loads no problem doesnt bend shaft etc 😉PS only seems to jam on the built under double ovens 😕
It was a built under double oven, bear in mind I was fitting a non gen element, the customer is moving to France in three weeks so didn’t want to pay for gen element. If I had left the top screw out it the fan would have hit the element, you know how badly formed a large number of pattern elements are 😥February 9, 2006 at 7:16 pm #162051iadom
It was a built under double oven, bear in mind I was fitting a non gen element, the customer is moving to France in three weeks so didn’t want to pay for gen element. If I had left the top screw out the fan would have hit the element, you know how badly formed a large number of pattern elements are 😥February 9, 2006 at 7:21 pm #162052Bryan
Nah Greg , small squirt , give it a good wipe down , leave it to run on low heat for 5 mins and all clear.
Each to their own I suppose.
Bryan
February 9, 2006 at 7:23 pm #162053gegsy
If it works Bryan I will give it a go. Give anythin a go once.
February 9, 2006 at 9:38 pm #162054aqualectric
Unfortunately, we’ve still not got to the root of the problem of these Mickey Mouse elements. Martin mentioned almost immediately there were mods for these ovens to sort out our woes.
Any info on the mods greatly appreciated – need an answer!!! 😕
Hope someone can help! :haier:February 10, 2006 at 12:56 am #162055Penguin45
Interesting how this is developing – I fit these elements quite regularly and have had no problems.
February 10, 2006 at 12:58 am #162056gegsy
Maybe your wings are stronger than our arms when pulling that soddin fan off 😆
February 10, 2006 at 1:00 am #162057Penguin45
Flippers mate, flippers…….
Chris.February 10, 2006 at 8:57 am #162058Bryan
Penguin45 wrote: I fit these elements quite regularly and have had no problems.
Chris.Which element are you using Chris ❓
I use ELE4080 , (14-NF-13 from SEME@£5:85)on Neff ovens where I can and don`t have any real problem with them.I do get the odd one failing in guarantee but nothing too severe.
I always give the area behind the back plate a good wipe down to get rid of the powdery residue and rub down any metal work damaged by the flare up.Bryan
February 10, 2006 at 6:55 pm #162059Penguin45
Qtex ELE6254 – the studs have screw threads which undo easily allowing use in different machines.
February 10, 2006 at 7:10 pm #162060Bryan
aqualectric wrote:Unfortunately, we’ve still not got to the root of the problem of these Mickey Mouse elements.
There you go then aqua , give that one a try 😀 . ELE6254 or perhaps you already have ❓
BTW is that identical to ELE4080 apart from the two , as opposed to one , studs which are easily removable ❓
Bryan
February 10, 2006 at 7:18 pm #162061Penguin45
Penguin45 wrote:have screw threads
Or even screw heads……..
June 11, 2008 at 3:35 pm #162062Martin
Go on, ask me how long a brand new genuine (494643) half moon element lasted when I fitted one recently? 😕
OK, to save you giving a bu&&er…… I’ll tell you……….. 🙁
30 seconds!!!! :rolls:
Brand friggin’ new, straight out of the cardboard packing and screwed into place nicely, fan back on, backplate screwed up, reset the oven clock and switch on, set to 150 degrees to test, fan spinning like a good ‘un, nice bit of heat being shed….then POP!!!!
Deep lasting joy, I’m done with fitting these sodding things…..!!!!! 👿
June 11, 2008 at 5:12 pm #162063gegsy
Not had any problems with them TBH. 😕
Now lightbulbs is another thing 😀Greg
