d-ray
  • in reply to: Hoover HFI 3015 /1-80 P1 light flashes continually #343634
    d-ray
    Re: Hoover HFI 3015 /1-80 P1 light flashes continually
    john@fisher-online.co.uk
    thanks for your help
    d-ray
    (John Fisher)
    in reply to: Hoover HFI 3015 /1-80 P1 light flashes continually #343632
    d-ray
    No did not know it had one so don’t know how to do it
    in reply to: Hoover HFI 3015 /1-80 P1 light flashes continually #343630
    d-ray
    Done that but keeps flashing and buzzing me think board is u/s
    in reply to: Indesits Partfinder #173604
    d-ray
    Re: Indesits Partfinder
    When partfinder is activated it writes to the registry (DO NOT GO INTO THE REG EDITOR UNLESS YOU KNOW WHAT YOU ARE DOING) in location [HKEY_LOCAL_MACHINESOFTWAREJVF Systems LtdPartfinder II] and the date is in the lic file in hex.
    If you put the date back you can stop other programs from working
    John
    in reply to: Servis Dishwasher M4605s #170857
    d-ray
    Re: Servis Dishwasher M4605s
    Went back today to fit a part to the tumble dryer and had another look at it.
    I took the sides off then switched it on and it worked ok so I left it.
    in reply to: Software for tracking customers / jobs. #166893
    d-ray
    Re: Software for tracking customers / jobs.
    I was asked to write a program for Crwys Electrics Ltd the requirements were
    1. Upto six engineers
    2. Eight calls a day
    3 Search data base with house number, name (part name), street (part name), phone number, or post code
    4 will print off work at the end of the day
    It has been working for 12 months now and has 13,000 entries in it
    I am now doing an upgrade to it as he now wants to put job returns in it
    I use mysql data base as it is free search time is less than one second
    I wrote it in visual basic.net
    If any one is in Cardiff and knows Paul ask him if you can see it as it saves him more than one hour a day.
    in reply to: Whirlpool C D #170554
    d-ray
    Re: Whirlpool C D
    I have been told Whirlpool will only supply them to there agents
    I need to find an agent to get me one
    in reply to: Whirlpool ADG7540/1 Rinse light on #161126
    d-ray
    Re: Whirlpool ADG7540/1 Rinse light on
    Went back today put on test program worked ok will wait and see if fault reoccurs
    thanks for the help
    in reply to: Diplomat 8152 dishwasher – spare parts #151311
    d-ray
    Re: Diplomat 8152 dishwasher – spare parts
    I use Drulight Ltd they will post spares 01443 812372
    in reply to: ADG 6552 7 flashes #142835
    d-ray
    Re: ADG 6552 7 flashes
    It was the plug on the flow meter
    Thanks again
    in reply to: ADG 6552 7 flashes #142834
    d-ray
    Thanks Dave and Brian will go back and have another look
    in reply to: Indesit autotest routine/Hardware key #135232
    d-ray
    Hi tubs
    what you are doing is putting vcc to the test pin
    from the top the pins are rx,tx,gnd,vcc and test.
    rx and tx is used to connect to pc
    the switch on the test plug puts vcc to test
    I have made 6 boxes for local engineers but what you are doing will work ok
    in reply to: **KNOWN ERROR CODES** #103878
    d-ray
    Re: Known Error Codes
    I have a pdf file of Indesit toploader.LVB2000,LS 12-E-2300 D/W
    and EVO 2 D/W
    I also know how to get the LVB2000 into test mode without the test plug
    I can send the pdf and details by e-mail just drop me a line
    oth_50@yahoo.co.uk
    in reply to: samsung parts required #116981
    d-ray
    Re: samsung parts required
    Many thanks Dave
    I have sent e-mail to samsung CPC supply the spares 0870 1202530
