Marty-K
ParticipantRe: Anonimo ASE3120 base oven element
Thanks Loaf, yep its like the APL3120 style no fan. The pt. no. you gave is actually the grill/oven element but by a process of elimination i found the base element pt.no. 082230600. Thanks for your help.
Marty-K
ParticipantRe: Hotpoint BWM20 valve
Thanks mate 😀
Marty-K
ParticipantRe: Bosch module Pt. No. 482935/489607
A Bosch SGS43A18GB/27
Marty-K
ParticipantRe: Cookerworks Signature fan oven
Yes you`re quite right, I did mean cookworks. I found the part at connect. It`s amazing what you can find when you get the name right 😳
Marty-K
ParticipantRe: Cookerworks Signature single integrated fan ovens
Thank you everyone, I did mean cookworks. I found the part at connect. It`s amazing what you can find when you get the name right 😳
Marty-K
ParticipantRe: Hoover HNWL7166-80
Thanks Chris 😀
Marty-K
ParticipantRe: hotpoint wdm73
I think the part your after is the WD motor mount kit Pt. No. 1601888. Its £4.70 + vat from connect and theres a picture of it as well 🙂
Marty-K
ParticipantRe: Whirlpool SIOS ?
Just received mine and installed it today but it won`t display any diagrams ❗ suppose i`ll have to try installing it again :rolls:
Marty-K
ParticipantRe: Masterpart ..not the best of starts
I`ve had this happen to me loads of times, and not just on low stock items either 😡
Marty-K
ParticipantRe: No Credit Card, No Repair
I`m glad to see its not only me that gets the abuse and out calls. Its funny how they always just had to “pop out” and they always seem to get back “just after you`ve gone” 👿
Marty-K
ParticipantRe: Diplomat ADP 8112 Dishwasher
I had this problem some time ago. It turned out to be the pcb at fault but you need to be sure you`ve eliminated everything else because its an expensive part to get wrong ❗ (Pt No 816290672 retails at £140 and available from connect for £95 + vat).
Regards
MartyMarty-K
ParticipantRe: Neff half turn elements
Ever bosch patten element i`ve fitted has failed within 12 months 😯 so I only fit gen ones now. Having said that i`ve had three of those fail under guarentee 😮
Marty
Marty-K
ParticipantRe: Ariston AFA370X
Yep thats the part :tup: many thanks Jim.
Regards
MartyMarty-K
ParticipantRe: Tecnik TKC230 single oven
Doesn`t anyone know where I can get parts for this ❓
Marty-K
ParticipantRe: Bl**dy Bosch!
Hi Greg,
Thanks for the confirmation and additional info, very helpful.
Regards
Marty -
