The-specialist
ParticipantRe: AEG FREEZER
i think you will find that the lower defrost heater o/c seeya 😆
September 18, 2006 at 8:17 pm in reply to: whirlpool large American tumble dryer 10 kg 110 volts #188854The-specialist
ParticipantRe: whirlpool large American tumble dryer 10 kg 110 volts
I think it has got a centrifugal start device on the motor will check it out but have already had megger on windings and they seemed to be fine .
thanks for your info 🙂The-specialist
ParticipantRe: Query on Tricity Sovereign oven
make sure when you turn the timer to off (000) that you have the 3 large zeros and not 3 small zeros as 3 small zeros is defrost mod and the fan runs constant just push oven button again and turn to get the 3 large zeros
hope this helps 🙄The-specialist
ParticipantRe: Tricity Bendix DH086
The air chamber is blocked m8.And overfilling .
You will need to fit new sump 😆The-specialist
ParticipantRe: Zanussi IZ 16 S with an E33 error code
True
Both codes to do with pressure system problems??
But have had this code for 1 of the heater wire fallen OFF .
Check this first it might save ya an Hour 😆 -
