Your_Uck
  • in reply to: creda tcr2 #167186
    Your_Uck
    Re: creda tcr2
    Ref getting lid off, simply lever the rear lugs with a flatblade s/driver and the lid will come off with ease 😀
    in reply to: Broken Bauknecht. #166598
    Your_Uck
    Re: Buggered Bauknecht.
    The base is the very bottom of the machine
    in reply to: scandinova getting noisier #166601
    Your_Uck
    Re: scandinova getting noisier
    Normaly ice builds up around evaporator fans, switch off and defrost for a good 24-36 hours with door left open(in warm enviroment) should sort it out.
    in reply to: ariston margherita AWD 12 selector knob turning #164147
    Your_Uck
    Re: ariston margherita AWD 12 selector knob turning
    Can get blocked in the sump hose (hose from drum to pump filter) or if your machine drain hose is connected to your sink waste it can get blocked there. Power off if going in machine
    in reply to: ariston margherita AWD 12 selector knob turning #164145
    Your_Uck
    Fault f5 :Normaly machine is not empying, check your filter at bottom of machine
    in reply to: Transporting a washing machine #164185
    Your_Uck
    Re: Transporting a washing machine
    This will be fine as the machine will have “transit bolts” or other packing suporting the drum keeping it ridgid. these are removed as per instruction book before use
    in reply to: Hotpoint Wf840 – Wool Wash Programme #164173
    Your_Uck
    Re: Hotpoint Wf840 – Wool Wash Programme
    On wool wash the drum tumbles at 90 rpm. The idea is the garments stick to the drum and do not rub together like on a normal wash.
    in reply to: Zanussi Help #162686
    Your_Uck
    Re: Zanussi Help
    No worries 🙂
    in reply to: Zanussi Help #162682
    Your_Uck
    Re: Zanussi Help
    these machines suffer from a bad solder joint on the pcb (heater relay) and can be repaired by re-soldering the bad joint
    in reply to: LEC Fridge Freezer #162679
    Your_Uck
    Re: LEC Fridge Freezer
    If the compressor runs for a few seconds then goes click, it is normaly the compressor that is faulty, would need an engineer to confirm this as could be a faulty relay/ptc unit but unlikly
    in reply to: Hotpoint WF640T : serial no 35116453 ; ” TEST ?” #162612
    Your_Uck
    Re: Hotpoint WF640T : serial no 35116453 ; ” TEST ?&amp
    your machines are in “demo” mode, to deactivate press start/cancel button until all leds illuminate then press start cancel and on/off at the same time until “d off” is displayed, your machine will then fuction normaly
