Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Ariston Margherita 2000 – I also have a problem!
- This topic has 251 replies, 66 voices, and was last updated 21 years, 9 months ago by
admin.
July 13, 2007 at 8:23 pm #112900
hotpnt
ParticipantRe: Ariston Margherita 2000 – I also have a problem!
7 flashes is a heat relay problem, if the heater wiring is ok then it’ll be the main board!, plug out if your gonna peek inside!!
July 13, 2007 at 9:45 pm #112901carolien
Thanks, I will check it out tomorrow!
If it is the main board, is it cheaper to get a new washing machine or is it worth repairing?
I just realised by checking the forum that my drying function never worked. The washing always gets hot but never dries. So I never use it!
Thanks for the help, will let you know what happened!
Carolien 😆July 14, 2007 at 4:46 pm #112902carolien
I have cleaned the filter and now there are no lights flashing any more. Washing machine partially fills up and just stays on (it doesnt stop and the dial does not move at all), drum does rotate.
If I change setting for washing machine to drain, dial rotates to original setting and stays stuck.
Has anyone got any idea what this means and if it can be fixed??Carolien
July 14, 2007 at 5:21 pm #112903Penguin45
Really does sound like the computer has packed up.
July 16, 2007 at 8:32 pm #112904wid77
ParticipantBearing question.
The spin cycle on our Ariston A1435S Advantage is getting gradually noisier as though the bearings are on the way out. The machine is now 5 years old so it would not surprise me. Can you tell me the part no. for the bearing kit so i can order from here? I think it is BKT74 but am not sure.
Thanks for any help.
PaulJuly 16, 2007 at 8:45 pm #112905Penguin45
As far as I can tell, you need AR05105. Drop an email to spares@ukwhitegoods.co.uk with the above part number and Dave’ll sort it out for you.
Penguin45.July 16, 2007 at 8:52 pm #112906Dave_Conway
BKT74 here:
http://shop.ukwhitegoods.co.uk/product_ … cts_id=514
Same part 😀
July 17, 2007 at 8:01 pm #112907wid77
Thanks for the advice chaps. I’ll get the bearings ordered asap.
Paul
August 7, 2007 at 11:53 pm #112908Boing
I have a Ariston Margherita 2000 AL 129 X Washing Machine. My problem is that the machine simply doesn’t clean my clothes, often resulting in still smelly clothes when the washing is done…
The machine washes only till a certain extent. Socks and other clothes that usually are smellier than other stuff, needs a good two or three rounds in the machine before they are wearable…
I’ve tried loading the machine with less clothes and doubling the recommended amount of washing powder.
I need help! My co-workers are “sniffing” intensely around me and are givin’ me funny looks.
-Smelly
August 8, 2007 at 7:25 am #112909Martin
Boing wrote:I need help! My co-workers are “sniffing” intensely around me and are givin’ me funny looks.
Read this Smelly. 😉
August 8, 2007 at 12:31 pm #112910Boing
Well, there’s no smell from the inside of the machine, it’s the clothes that smell. The reason why I excpect it be something wrong with the washing, is that for example my washed t-shirts typically only smell under the armpits, and the socks only smell on the part that actually go inside the shoe.
-Smelly
August 8, 2007 at 1:31 pm #112911Martin
Boing wrote:Well, there’s no smell from the inside of the machine, it’s the clothes that smell.
Smelly, stop with the wind-up my friend, just read the article I linked to and be done! :rolls:
August 9, 2007 at 2:28 pm #112912Boing
I did, but it contained no information that could help me.
That’s the reason I specified that it wasn’t the machine that smelled.
August 9, 2007 at 2:47 pm #112913Martin
Boing wrote:I did, but it contained no information that could help me.
Well I’m sorry we couldn’t help you Smelly….at least we tried 🙁
August 9, 2007 at 2:52 pm #112914kwatt
KeymasterRe: Ariston Margherita 2000 – I also have a problem!
Is this on all wash cycles Boing or just one and, if it is just on one or two, which ones?
