Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Ariston Margherita 2000 – I also have a problem!
- This topic has 251 replies, 66 voices, and was last updated 21 years, 9 months ago by
admin.
April 14, 2007 at 1:25 pm #112885
hotpnt
ParticipantRe: Ariston Margherita 2000 – I also have a problem!
hi, the drier dial just needs to be set to zero, it may be a push in/out dial to see the settings
April 14, 2007 at 5:43 pm #112886irtosik
hotpnt wrote:hi, the drier dial just needs to be set to zero, it may be a push in/out dial to see the settings
we’ve tried already to set the drier dial to zero,but it still workes.so now we need to try how it works when it is pushed out 😀 Right? because before I pushed that button in (during working of the maschine) to hide it from my kid 😆 thanks!I will check it today!!
April 14, 2007 at 5:59 pm #112887hotpnt
no, it does not matter if the knob is pushed in or out, it has no effect, its just a child proof thing, if it still works when the dial is set to zero it may either be a faulty switch or more commonly if you REMOVE THE PLUG and remove the lid, the small plug on the back of the drier dial may have come off, this makes the machine do a dry cycle after every wash
April 14, 2007 at 6:28 pm #112888irtosik
hotpnt wrote:if you REMOVE THE PLUG and remove the lid, the small plug on the back of the drier dial may have come off, this makes the machine do a dry cycle after every wash
I’m sorry but I don’t understand due to my english language level 🙂 can you explain me one more time.What should I do after I remove the plug and the lid?I should switch off something? 🙂
April 14, 2007 at 6:30 pm #112889irtosik
irtosik wrote:
hotpnt wrote:
if you REMOVE THE PLUG and remove the lid, the small plug on the back of the drier dial may have come off, this makes the machine do a dry cycle after every washI’m sorry but I don’t understand due to my english language level 🙂 can you explain me one more time.What should I do after I remove the plug and the lid?I should switch off something? 🙂
I think I understand you! can I do it by my own or it must be done by professional?
April 14, 2007 at 6:46 pm #112890hotpnt
depends, you must make sure the machine is unplugged from the mains first!!, when the lid is off just look at the back of the dryer dial/switch & make sure there is a small plug with 2 wires connected to it
April 14, 2007 at 6:54 pm #112891irtosik
thank YOU hotpnt!!! My husband just removed the lid and found out that a bunch of wires from the drier dial was torn.he fixed that.I think the problem was in that!we’ll check it out today! 😀
June 10, 2007 at 4:22 pm #112892boarlet
Hi..
I have a AL128D washer/dryer.
Can someone advice me how to disable the dryer functions.
I have been trying to use the preset funtion [numerical set found on the powder loader plate]…But it seems that all function must go thru the drying cycle…. I have set the dryer to zero but the drying cycle still comes on at the end of the cycle…Pls help….tks
June 13, 2007 at 10:06 pm #112893Gizzmo
Hi, I have an Ariston Margherita 12S advantage, have had it for 2 years with no problems then tonight it has stopped part way through a cycle, full of water.
I’ve read through a few of the posts here and have removed te kick panel at the bottom of the machine and unscrewed the round black bit….not sure what to do next as it doesn’t seem to want to come out any further for me to look at it (is this the filter?)
Any advice gratefully received, clear intructions required if at all possible as I have absolutely no idea what I’m doing….
General waste pipes are fine as the sink is draining with no problems.
Helen
June 13, 2007 at 10:27 pm #112894helo_75
Participantif the filter doesnt come out easily, theres something in there blocking it
unplug the machine, tip it back, remove the screws securing the pump, take off said pump, remove back pumpbase, refit, refit pump, presto.. easy really
just remember u need to unplug it for sure, and have lots of towels
June 13, 2007 at 11:38 pm #112895Penguin45
Drop the drain hose into the washing up bowl first and see how much water you can get out ………..
June 17, 2007 at 9:57 pm #112896Gizzmo
Okay, I got the filter out and had a look and cleaned it, there was only a 1 penny piece in there…..the hose seems to be clear as well.
switched it back on and it seemed to start okay, then stopped again after 15 mins (on program 8) and started that gantastic clicking it does, still 5 flashes on the light.
Any more ideas?
Helen
June 18, 2007 at 12:01 am #112897Penguin45
5 flashes has nothing to do with the pump. It specifically means that the water level switch is jammed in the closed position – the machine thinks it’s full of water. This can be caused by two things – the switch itself has failed, or the collecting chamber in the bottom is full of horrible sticky goo and is blocking the hose to the switch.
Power off before investigating, please.
June 18, 2007 at 8:24 am #112898Gizzmo
Dare I ask how I investigate this? Where is the switch etc etc?
July 13, 2007 at 4:01 pm #112899carolien
Hi, I have the same problem!
My washing machine’s dial started turning (no idea where in the cycle it was! but washing was wet, powder was gone but conditioner was still in tray) and no when I try to reset it as you mentioned before, it does not want to do that.
I can turn the machine on, the red light goes on, I can hear the water running and I think it starts heating it up and then the light goes off and the dial starts turning and the lights flashes 7 times. 🙁My machine: Ariston Margherita 2000 AWD 12S Advantage.
S/N: 403108851*80260970030.Is there anything I can do or should I call out an engineer? :rolls:
Thanks,
Carolien -
