Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Ariston Margherita 2000 – I also have a problem!
- This topic has 251 replies, 66 voices, and was last updated 21 years, 9 months ago by
admin.
October 8, 2007 at 9:25 am #112930
Duz
ParticipantRe: Ariston Margherita 2000 – I also have a problem!
Thanks penguin45! exactly what I needed, cheers.
January 11, 2008 at 1:04 pm #112931fvm
I have a problem with my Ariston Margherita 2000 AL129X.
The wash starts,water enters the drawer, and then being pumped out again after (about) half a minute, and then the dial starts clicking around the cycles.
From reading all the other threads,I counted the flashes, there were 2 of them. 😕
Any ideas???Frank
January 11, 2008 at 4:39 pm #112932iadom
ModeratorRe: Ariston Margherita 2000 – I also have a problem!
Not good news, suggests motor jammed or faulty, can be a loose connection on the motor plug or module. Please remove the mains plug if you intend to have a look inside.
January 13, 2008 at 9:58 pm #112933HuntersBar
ParticipantMore AWD12S woes
I have an Ariston Margherita AWD12S, S/N 212113749. It is about five years old.
It started playing up recently, so I checked the pump and removed a strip of metal that had come from a shirt. Now it behaves as follows when turned on on any programme:
– fills with water (couple of inches visible in drum)
– heater operates until some condensation is visible inside door (2-3 mins)
– No activity or noise for about five mins
– Pump kicks in and drains the machine and then continues pumping once there’s nothing left to pump
– Only way to stop it is to turn it offDuring this time, the light stays on and the dial remains in the original position.
I’ll add that previously I’ve had to remove an object from the pump, with seemingly no ill effects.
Also, recently a wedge I have under one of its feet to keep it level became dislodged, resulting in pretty hefty vibrations. I replaced the wedge and it seemed ok for a few washes before the current problems. I don’t know if that’s relevant, but if I was a cicuit board in there, I’d be dizzy at the least!
If it’s any help, I can put a video of it on youtube.
TIA,
Martin.January 13, 2008 at 11:51 pm #112934Penguin45
Check the carbon brushes in the drive motor. They don’t give a fault code.
Power off before going underneath.
January 14, 2008 at 4:09 pm #112935HuntersBar
That sounds probable.
Quick question to help confirm: On this model, should the drum rotate during the heating cycle?
I ask as I noticed the drum seems to move a degreee or so when the heating cycle starts, suggesting the motor tries to turn, but can’t.
January 14, 2008 at 5:40 pm #112936iadom
Do you mean the heating cycle or the drying cycle. The drum should revolve during either but during the heating cycle it may only do very short tumbles, much longer tumbles during drying cycle.
January 14, 2008 at 8:31 pm #112937HuntersBar
It’s during the initial heating cycle.
I’ve inspected the motor and, to my eye, it looks in pretty good condition. You can see for yourselves:
http://83.105.37.252/share/14012008126.jpg
http://83.105.37.252/share/14012008128.jpg
http://83.105.37.252/share/14012008130.jpg
http://83.105.37.252/share/14012008132.jpgHave you any recommendations on how to proceed from here?
I really appreciate your help.
MartinJanuary 14, 2008 at 9:23 pm #112938Penguin45
Unscrew the brush holders and make sure there is plenty of carbon stick left in them. Ensure free and easy movement.
You said the motor pulsed slightly – did it make an “ong” noise?
January 14, 2008 at 9:41 pm #112939HuntersBar
Yes, for a few seconds, then the noise stops. Then you can hear the water warming up.
January 14, 2008 at 9:52 pm #112940Penguin45
Armature in the motor has lost the will to live. If you take the belt off, the motor may turn over very slowly.
New motor required – can’t honestly justify the expense in relation to the value of the machine.
January 15, 2008 at 8:57 pm #112941HuntersBar
Yes, exactly as described.
However, I have two questions:
- How much for a new motor?
What error code does eight flashes of the light mean?January 15, 2008 at 9:48 pm #112942Penguin45
Motor is p/no C00074221 – Dave on spares@ukwhitegoods.co.uk will give you a price.
8 flashes specifically means a problem with the heater relay on the pcb. It actually means that the pcb needs to be replaced, 19 out of 20.
January 15, 2008 at 10:17 pm #112943HuntersBar
Do I win a prize?
:o)
Looks like I’ll be shopping tomorrow. Thanks for your help.
MartinJanuary 16, 2008 at 12:17 am #112944Penguin45
I’m afraid you join a long list of the disappointed……..
If you start from the viewpoint that a washer-dryer is a deeply flawed beast in the first place, then add The Indesit Company’s idea of engineering, you really don’t have much chance of long, reliable product life.
If you have to have a washer dryer, the Electrolux Group products are OK, Bosch is better. Personally, I’d buy a washer and find somewhere to put a compact tumble dryer. They’ll do a surprising mount of work.
