Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Whirlpool American Fridge Freezer broken down – help!
- This topic has 821 replies, 256 voices, and was last updated 20 years, 9 months ago by
admin.
September 15, 2009 at 10:18 am #142232
2twotoes
ParticipantRe: Whirlpool American Fridge Freezer broken down – help!
hi all i have the same problems as most of you but my fridge freezer is still working i have the flashing lights the spurting water and the clicking sound every 20 mins for about 15 secs but as ive said still working my problem is that my fridge lights have gone out i have replaced the bulbs as the one i took out had blown but to no avail it seems that i have no power there as anyone got any ideas or is this the start of many problems i have insurance with D&G but labour only so unsure if i should call them out or not my father in law is a radio t/v enginer advice please many thanks
September 15, 2009 at 10:20 am #1422332twotoes
sorry model no S20D RSB33-A/G service no 8586 158 15010 11 4021 018206 thanks
September 15, 2009 at 12:45 pm #142234broddersbaldrick
Hi 2twotoes,
There is a kit on this forum which will solve all your problems.
It’s on page 25 and put together by ‘kwatt’ look for the duck avatar πI would recommend it for your list of faults.
bbSeptember 15, 2009 at 12:45 pm #142235raceboy
Now I’m no expert but I do think the light issue may be linked to one of the other issues.
Mine has recently been repaired by Brodders, I’ve had every failure going until it gave up working completely.
It probalby took about 2 years from first ‘click’ issue to complete failure but knowing what I know now I’d fix it sooner rather than later. π
A year or so ago my freezer light went ‘pop’ tried the one out the fridge and it didn’t work so I just left it, now the unit is repaired I tried swapping them over again and now it works.
I just need to get a new bulb now…..which leads to my question……
The bulds advertised for the ‘american’ whirlpool are Β£15 and 40w rated where as every other bulb with what looks like the same fitting but rated at 20w are about Β£2
Will the cheap bulb fit and ‘just be a bit dimmer’ or is it me being dimmer and there’s more to it than that?September 15, 2009 at 1:04 pm #142236broddersbaldrick
Hi raceboy π
If the cheap ones fit, thare’s no other problem.
broddersSeptember 15, 2009 at 1:46 pm #142237Wadey24
I had this problem a couple of years ago, but until recently it seemed to have cleared after I’d taken the rear board out to examine it.
A couple of months ago it came back with an irritating vengeance – so I ordered and fitted the rear board mod from UK Whitegoods, which didn’t solve the clicking but should help it live a bit longer.
The clicking appears to be coming from a relay on the front board, so I’ve just ordered two 1uF capacitors from RS (Β£7.51) inc delivery – so will post with the outcome.
Many thanks to Brodders for the advice π
By the way, I’d be really grateful if you can tell me where I might source a replacement relay for this board – just in case the contacts are about burnt out π
(Mine is an S20BRWW20A/G and the front board has 103-0234 stamped across it).
September 15, 2009 at 2:06 pm #142238broddersbaldrick
Hi Wadey24,
I’ll look into the part number of the relay but I think it will be ok.I’ve mentioned to ‘The Powers That Be’ that C2 on the rear board can cause problems.
1000uf
6.3 volt
3.5mm lead spacingWhen all the other caps are failing, this C2 little bugger can cause Havoc all by itself and destroy your compressor relay if left long enough.
Itβs not the βusual suspectβ but has been known to cause failures.Your 1ufβs will cure your front board π
brodders
September 15, 2009 at 2:10 pm #142239kwatt
KeymasterRe: Whirlpool American Fridge Freezer broken down – help!
Okies, this is a work in progress that may well change over time as we learn more but, I hope, to keep it up date with as much information as we have.
Full instructions with pictures of the rear electronic control unit repair
Please do take note that, as stated, this is most definitely NOT a “cure all” for these machines, there are other components that can and do go faulty.
The repair kit is here and will likely be updated in the next few days with an additional capacitor, C2, that can go faulty. Many thanks to broddersbaldrick for sharing that gem. π
If you have already ordered a kit, still have a problem and want to try the C2 cap as well email me a copy of the order to kwatt@ukwhitegoods.co.uk and I will post you the additional cap FOC.
Hope that helps.
September 15, 2009 at 2:53 pm #142240Wadey24
Thanks Brodders. I’m only up the road (York), so if the clicking continues after the front board mod I might need to book your services & expertise!
Will keep you posted…
Thanks also to Kwatt for the C2 update π
September 15, 2009 at 4:24 pm #142241daddykool
Never was so much done by so few!!!!!
September 15, 2009 at 5:02 pm #142242broddersbaldrick
Hi Wadey24,
The RS part number for the front relay is 369-517
It has a life span of 15’000’000 cycles; if yours has been clicking a few times each hour for the last few months; you have until you’re 150 years old to replace it (approx) π
I’d leave it, and if your ice stops dispensing, we can pop to daddycools place once he’s fitted the front caps. π
September 15, 2009 at 11:01 pm #142243joeyo
Hi all,
I’ve just registered on the forum to add my gratitude and thanks to broddersbaldrick.
With John’s expert guidance I’ve managed to successfully replace the caps on both the back board and front board of my whirlpool S20B RSB21 American fridge freezer and it is now fully functioning again.
Heartfelt thanks for all your effort, and kindness …
Joe.September 16, 2009 at 12:23 am #142244rikmak
hi joeyo , do you mind me asking wot was wrong with your f/f m8
September 16, 2009 at 2:28 am #142245Ozzy1
Hi there all
It has been quite some time since I first posted on this site regarding the Capacitor problem. It is good to know that others have been successful in stopping the clicking and spluttering faults too.
My fridge has been OK for over a year after changing the capacitors, but now I have a new problem with the compressor I think.
First sign was temp increasing and eventually alarm sounding.
After cleaning the fluff off the condensor coils and a full defrost, (there was a large qty of ice build up on the evaporator) all seemed OK for a few days.
Now I have noticed that the compressor is running continuously and getting quite hot. The freezer and fridge appear to be OK and at correct temps.
The compressor fan runs OK but switches off even though the compressor is still running. I thought it is supposed to run at all times the compressor is running?
The internal evaporator fan switches on and off as required but the compressor continues running.
Only way to stop the compressor is to switch off the mains switch.
After 8 minutes, it starts up again.
The standby switch also does not stop the compressor from running.
I am thinking that it could this be a sticking relay or has anyone got any ideas how to diagnose this fault ?September 16, 2009 at 7:30 am #142246broddersbaldrick
Hi Ozzy1
The compressor relay is a ‘change overβ relay.
When it’s not running the compressor, the contacts ‘change over’ and supply the 220volt power for the ‘defrost relay’The Defrost circuit will not and can’t work if the compressor is running.
If the contacts have stuck, your fridge will never be able to defrost.
The ‘standby’ powers up another relay to turn off the whole fridge freezer, which will kill the signal to the compressor relay but not the 220 volt.
It does sound very much like the orange relay is sticking, probably due to burnt and arcing contacts.
That relay is available for about Β£3 from Farnell 117-5017 and they have free shipping π
Hope this helps
brodders
