Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › zanussi zwd147s tub seal seems an odd one
- This topic has 195 replies, 18 voices, and was last updated 15 years, 2 months ago by
stryder.
March 10, 2011 at 7:06 pm #341478
ModeratorRe: zanussi zwd147s tub seal seems an odd one
What hapened to the one that odom offered?
March 10, 2011 at 7:23 pm #341479stryder
ParticipantRe: zanussi zwd147s tub seal seems an odd one
he sent it out but it never arrived, the royal mail doing their usual bungling. odom has refunded the money, just waiting for it to show on the statement.
March 10, 2011 at 8:01 pm #341480iadom
Bummer. 😥
March 10, 2011 at 8:09 pm #341481stryder
your telling me!
wish i could get this finnished 🙁March 10, 2011 at 8:43 pm #341482quickwash
At least you are trying!
Good luck, hopefully better luck than you have had with Royal Mail that’s for sure :rolls:
quickwash :plug:
March 10, 2011 at 8:45 pm #341483stryder
thanks quickwash 🙂
March 11, 2011 at 8:28 pm #341484stryder
boselecta are you receiving? :)i sent you a pm
March 12, 2011 at 1:00 am #341485leavemetogetonwithit
Pretty sure that motor runs on 240v, not stepped down. Might be a label on it somewhere (may have dropped off) to say so. The black dust may come from the little belt that it uses to drive the fan (unless they’ve changed the design).
Mike.March 12, 2011 at 7:36 am #341486stryder
hi mate
i reckon your right , the belt did have a fair bit of the black dust on it.March 12, 2011 at 9:30 am #341487stryder
hi mike
connected it up to 240v supply and guess what-the motor works!
so i don`t need a new one . i put a bit of load on it and still no probs . the metal casing gets a bit hot but i supposed thats what the fan blades underneath are for.
if it still runs intermittently when i put it back on the machine it must be something else causing the problem. i`ve checked the wiring and cleand all connections. i hope its not a fault on the board :eeek:March 12, 2011 at 10:59 am #341488Martin
stryder wrote:if it still runs intermittently when i put it back on the machine it must be something else causing the problem.
I doubt it TBH, more likely the phosphor-bronze bearings seize up through lack of lubrication or the air gap between rotor and coil uneven due to excess bearing wear. But I’m sure you must have squirted liberal doses of 3 in 1 oil into the bearings anyway, have you?
March 12, 2011 at 11:23 am #341489stryder
hi martin
i put a bit of bearing grease in them but to tell you the truth they seemed fine before i did. they spin really smoothly without any play. i did find some crap stuck to the stator(not sure if thats what you call it in an induction motor) so i cleaned it up with some servisol. its been running constsantly now for about 1 and a half hours with no problems. i wish i could find out what the restistance should be across the terminals.also it doesen`t appear to have any kind of thermal cut out as someone suggested.March 12, 2011 at 12:51 pm #341490stryder
is it normal for the metal casing to get fairly hot after its been running for a while . if someone out there has a new one is there any chance they could give it a quick check with a multimeter and tell me what the resistance is across the two spade connectors? then maybe i can get a decent nights sleep and stop thinking about the bloody thing 🙂
March 13, 2011 at 8:02 pm #341491stryder
i would like to just correct my last post- its stopped spinning again. I GIVE UP ! 🙁
March 14, 2011 at 12:12 am #341492leavemetogetonwithit
Do you mean the dryer motor has stopped spinning or the drum?
As regards the dryer motor, don’t worry about resistance of coil. It would be very unusual if that was “wrong” without definite signs of burning! Also, it would need to have had a fair bit of use before the bearings in it would wear. Your problem is most likely elsewhere. Clogged condenser perhaps or just possibly iffy connection somewhere. Check especially connections to all thermostats / thermistors. There’s probably one in the condenser to sump hose you might not know about. Anyway, you’ve got a washing machine at least, haven’t you?
Mike. -
