zanussi zwd147s tub seal seems an odd one
Home Forums Public Support Forums Help And Support Washing Machine Help Forum zanussi zwd147s tub seal seems an odd one
Viewing 15 posts - 76 through 90 (of 196 total)
  • #341403
    stryder
    Re: zanussi zwd147s tub seal seems an odd one
    thanks quickwash.
    i`ill let you know when its back together if it actually works.
    #341404
    stryder
    hi everyone , i`m back again and guess what .. i still haven`t finnished this 😆
    i`ve got yet another question – under the heater blower duct
    where the wiring runs there is a connector with 3 wires in it , 1 orange, one brown and one grey, the problem is theres nothing for it to plug into . i have come across stuff in the past where they had used a connecter plug to terminate wires or just join them together , could this be what this is?
    could some kind person please advise as i`m getting close to finnishing this . i can see the light at the end of the tunnel 🙂
    #341405
    helo_75
    im pretty sure thats just a spare plug
    is it time to get the champagne out and celebrate the fix?
    #341406
    stryder
    thanks mate .
    just got a couple more things to do on it then i`ll plug it in and light the fuse and stand well back 🙂
    #341407
    quickwash
    Look at the time i have stayed up to see if you have got the machine ‘up and running’ yet :rolls:
    Just kidding, was up anyhow and just saw your latest post!
    Hope all goes well 😀
    quickwash :plug:
    #341408
    stryder
    hi quickwash
    i still havent finnished this, i don`t get much spare time to work on it at the moment . pity i`m not doing this as a job , if i charged by the hour i`d be loaded 😆
    there again i think my customers would just give up and buy a new washer!
    #341409
    quickwash
    :lol2:
    #341410
    Seamy
    3 weeks now we’re waiting on ya to finish it 😆
    #341411
    Seamy wrote:3 weeks now we’re waiting on ya to finish it 😆
    …..include photo’s maybe? 💡
    #341412
    stryder
    hi again – theres good news and bad
    the good news is its back together. i connected it up to the water and plugged it in at the mains, all seemed fine, no error codes and spins really quiet(at the moment) only problem is its draining right away but not filling. if i`ve mixed the wires on the drain pump and the recirculation pump could this be the problem?
    #341413
    stryder wrote:if i`ve mixed the wires on the drain pump and the recirculation pump could this be the problem?
    I cannot imagine that would be possible anyway. 😕
    IIRC the drain pump comes on for a few seconds before it fills, whatever programme you use. So if it refuses to fill altogether then I suspect the problem a little more, shall we say, complex. 🙁
    By the way, can you furnish us with the exact model number and PNc number. I have a sneaky feeling we’re gonna need more ammunition to crack this. 😛
    #341414
    stryder
    hi martin
    it is a ZANUSSI ZWD 1471S, PNC 914601117 00
    TYPE-P6348480
    SERIAL NO.-53800028
    #341415
    quickwash
    #341416
    stryder
    is the pump nearest to the back and at the bottomof the machine the recurculation pump and the one at the front at the bottom the drain pump? if so i have two blue wires conected to the recirculation pump and two orange wires connected to the drain pump, is this right?
    #341417
    Seamy
    Front pump at filter is drain. Cables to drain pump connect to PCB connections J3 2&6, recirculation pump connects to J11 1&2
