AJC_Dave
Viewing 15 posts - 1 through 15 (of 89 total)
  • in reply to: Hotpoint 9404 No Spin #396006
    AJC_Dave
    Re: Hotpoint 9404 No Spin
    I do and am sure it probably seems very novice. Still, very grateful for the advise.
    in reply to: Hoover VHC691b Capacitor #396055
    AJC_Dave
    Re: Hoover VHC691b Capacitor
    Thought so much. Good idea regarding the coathanger!
    in reply to: Hotpoint 9404 No Spin #396004
    AJC_Dave
    Thanks… Great help as I’ve never worked on one. This looks in really good condition for its age, so I really want to fix it.
    in reply to: Hotpoint 9404 No Spin #396002
    AJC_Dave
    trade-technical/hotpoint-9404w-t51550-15.html?hilit=twin tub clutch
    Should have searched a bit more!
    in reply to: Samsung WD17004RJE2 #394879
    AJC_Dave
    Re: Samsung WD17004RJE2
    Thanks for the advice.
    Got her the Samsung a few weeks ago as she was set on having it after seeing reviews on the internet.
    Don’t know about Beko washer dryers. Usually sell Bosch ones where I can but will have a look at Fagor in future.
    Thanks again
    in reply to: Work Mat #395768
    AJC_Dave
    Re: Work Mat
    Thanks…will pop in tomorrow and have a look.
    in reply to: Indesit IWC6105 #394667
    AJC_Dave
    Re: Indesit IWC6105
    Thanks.. Sounds good to me. Went back today and got no further so have ordered a new machine for her. Thanks again
    in reply to: Indesit IWC6105 #394665
    AJC_Dave
    Re: Indesit IWC6105
    Hi.. Yep, water emptied and filter cleared as when I first moved it I could hear coins in the sump hose. Didn’t re-set the pressure switch but did disconnect the hose to check it wasn’t blocked at the bottom. The pcb was off a machine with the bearings failed which I always do when I go out to them, so can’t be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}. Looks like that may be the problem. Going back tomorrow to have another look. Thanks for your help..
    in reply to: Merc Vito 113 #393548
    AJC_Dave
    Re: Merc Vito 113
    Its the injectors and fuel pump that have made me decide to change. Apparently a lot of injector problems arise from the fuel pump starting to fail and bits of it getting into the fuel lines. A quote of £1800 (worst case scenario) was enough for me to decide to get rid of it as its not worth much anymore.
    Got told to change the transmission oil in it every 30k as they can fail early too. Seems to have worked as its the best part of the van.
    Did buy it cheap at 9 month old with 15000 miles for £7100 + vat so can’t complain too much.
    in reply to: Merc Vito 113 #393546
    AJC_Dave
    Re: Merc Vito 113
    That’s what I’m after; something that I don’t get into with the fear that another expensive repair is just around the corner which seems to be the case with the Vivaro/Trafic/Primastar range. I know you can be unlucky but a pal that’s an electrican got his the year before me (Trafic)new and he’s had a new engine costing £4k at 80,000 plus power steering pump and starter before that.
    Think a vito it is then….
    in reply to: Belling 611GR Grill Element #393437
    AJC_Dave
    Re: Belling 611GR Grill Element
    Thanks..
    in reply to: Hotpoint TCL770 #392938
    AJC_Dave
    Re: Hotpoint TCL770
    Customer just called to say all is fine and the dryer is heating. Got a feeling that it may be short lived as it heated when I tested it at the start then was cold 15 mins later.
    Had a look on connect for the sensor and it is out of stock so won’t have one to go back with.
    Does anyone know if there’s a known problem with these sensors like the washer dryer NTCs or is there cases of pcb problems related to sensing the the mositure and mass of the load?
    Sorry for the amount of questions… I’ve only ever dealt with faults on the older system.
    thanks for any help
    in reply to: Hotpoint TCL770 #392937
    AJC_Dave
    Re: Hotpoint TCL770
    Thanks Jim
    in reply to: WMA PCBs #392656
    AJC_Dave
    Re: WMA PCBs
    Got some…thanks anyway.
    in reply to: WMA PCBs #392655
    AJC_Dave
    Re: WMA PCBs
    Usually one a week for all sorts of reasons from dead to interlocks. Can fix some but not many.
