A1_Domestics
ParticipantRe: hotpoint bwm129(integrated)
Defo two man job with machine on back with a trolley. I’ve cut my fingers something silly trying to do it on my own.
A1_Domestics
ParticipantRe: Beko DRCS68
Cheers Dave,
Model is Drcs68w. Havn’t got serial at hand.
E Mail is washerguys at msn dot com.
November 3, 2010 at 12:53 pm in reply to: AEG washer dryer – Timer resetting to zero on dryer programs #334688A1_Domestics
ParticipantRe: AEG washer dryer – Timer resetting to zero on dryer prog
I replaced that last year. Can see it working away at the mo. But it could be intermittent so I’m popping by this afternoon and watch it go.
A1_Domestics
Can I get some of this?
Ta
November 2, 2010 at 6:51 am in reply to: AEG washer dryer – Timer resetting to zero on dryer programs #334686A1_Domestics
I should mentioned that I cleared the gunk from the condenser and checked the wires on the stat.
A1_Domestics
ParticipantRe: WMA64 door wont lock
I’ve had similar problems before, found that if there is 240v on the door lock connector than usually it’s just a bad contact.
Squeezing the contacts together usually sorts it.
A1_Domestics
ParticipantRe: hotpoint wf440p dead
I had to replace a console pcb on one of these yesterday. Try a spare if you have one first.
A1_Domestics
ParticipantRe: Lg Washing Machine Module PCB DEAD
Trace the blown components to the source.I’m guessing it’s not the heating element, or pressure switch. Everything else is a Culprit IMO.
A1_Domestics
ParticipantRe: Hotpoint TDC30 no heat not stats
Are you getting live to the stats?
What resistance is there on the elements?Sorry if this obvious.
A1_Domestics
ParticipantRe: Hotpoint FF200E Fridge Freezer
I’ld appreciate some help with this too. Got one to look at in the morning.
A1_Domestics
ParticipantRe: Using Search facility
I’m hoping I’m not preaching to the choir here.
The best way to search IMO is using the asterisk character. Using asterisk would help with Martins issue for ZWF machines. The asterisk is a wildcard character, like the question mark character and others.
http://www.googleguide.com/wildcard_operator.html
I’ve just posted a question regarding a WF541 machine. Searching for WF541 returns 37 results, but it’s too wide. Searching for “WF541 f01” Only returned 1 result using the second radio button.
I found much more help using “wf* f01” and the second radio button.
Maybe, the second radio button should be the default, then we wouldn’t need to use regular expressions like: AND, OR.
September 1, 2010 at 4:42 pm in reply to: Hoover HNF3157 1500rpm washer spins for only 2 & 1/2 min #325370A1_Domestics
ParticipantRe: Hoover HNF3157 1500rpm washer spins for only 2 & 1/2
I got similar problems on a nextra hnl2126.
Needed new brushes, duely done, but now, the spin struggles with the usual weight.I’ld appreciate a test PDF to see what’s occurring.
A1_Domestics
ParticipantRe: Zanussi DE6544 D/W motor pumping strangely
Is there a capacitor on this motor?
A1_Domestics
ParticipantRe: Few12 program module help
For future reference, the wires on the board going to the pressure switch and the heating element were crossed.
in the past this had the effect of not releasing the door lock, but on FEW machines causes no fast spin. Luckily, the pcb has not been affected.
A1_Domestics
Participant -
