bobokines
Viewing 15 posts - 316 through 330 (of 760 total)
  • in reply to: Beko (prewash light flashing?) #197771
    bobokines
    Re: beko
    I think the prewash light flashing is a time out on fill.
    Bob
    in reply to: Servive M9813W #197726
    bobokines
    Re: Servive M9813W
    Check the edge connectors. I have seen edge connectors that track between terminals. It’s possible that a short may be supplying both the cold valve and the pump at the same time.
    Have you meggared the machine. An earth fault on the heater can cause strange faults.
    Have you checked the obvious. It’s not simply syphoning because the drain hose is too far down the standpipe.
    Bob
    in reply to: Beko Fault #197533
    bobokines
    Re: Beko Fault
    This machine does advance quickly through to that position before it heats and then heats to the temperature of the preselected program. Have you checked the temperature or are you just assuming that it’s only heating to 40C?
    Bob
    in reply to: Bosch dishwasher SGS43C12GB/15 not heating #197526
    bobokines
    Re: Bosch dishwasher SGS43C12GB/15 not heating
    Nobody has mentioned on this thread that the most common cause of no heat in these machines is a bad solder connection on the heater relay on the module. This is very obvious visually.
    Remember that the heater is switched in the neutral.
    Bob
    in reply to: HOTPOINT TDC62S #197283
    bobokines
    Re: HOTPOINT TDC62S
    I have one of these today doing the same thing. I can’t find anything wrong apart from a bulge in the side of the capacitor. The machine seems to have plenty of starting torque but the capacitor may be breaking down when hot.
    I have replaced the capacitor and left the customer to put it though a few vigorous tests,
    I will let you know the outcome
    Bob
    in reply to: hotpoint wma10 help again!! #197169
    bobokines
    Re: hotpoint wma10 help again!!
    Sorry Phil, the info I sent is for the wrong model.
    I’m sure Jim can help.
    JIM! where are you?
    in reply to: hotpoint wma10 help again!! #197168
    bobokines
    Phil
    You have mail
    Bob
    in reply to: hotpoint wma10 help again!! #197166
    bobokines
    It’s the pressure switch. The switch has gone out of calibration and there is too small difference between the normal water level and the overfill protection level.
    Bob
    in reply to: Smeg DWF410SS on off Switch #196844
    bobokines
    Re: Smeg DWF410SS on off Switch
    Thanks boys
    Much appreciated.
    Bob
    in reply to: Smeg DWF410SS on off Switch #196842
    bobokines
    Thanks Chris. I can’t find the switch listed under any of my suppliers. Do you have source for this part.
    Bob
    in reply to: SGE 12 X #196565
    bobokines
    Re: SGE 12 X
    It’s an Indesit in disguise.
    It’s branded as New World and is shown on Connect Mediator. Don’t fall over when you see the price of a door frame…
    5031680684957
    C00116566
    Bob
    in reply to: Diplomat 8702 Pressure switch #196284
    bobokines
    Re: Diplomat 8702 Pressure switch
    Thanks so much
    Bob
    in reply to: creda t622cw #196235
    bobokines
    Re: creda t622cw
    If the condensate bottle (Bucket to you) 😉 has a cap, check that the air breather hole is clear. The later bottles do not have a cap.
    Bob
    in reply to: how many words can you make out of indesit-hotpoint #195867
    bobokines
    Re: how many words can you make out of indesit-hotpoint
    it don’t spin it!
    :rolls:
    Bob
    in reply to: Stock control system #196034
    bobokines
    kwatt wrote: any I’ve seen have either been a hodge-podge of an accounts package
    We use Quickbooks for all our accounting needs. The stock control couldn’t be simpler. Any items purchased are keyed in on a daily basis and all parts used are recorded on the invoices and keyed as a usage.
    It has its limitations and problem (mostly due to duplicate part numbers when items are sourced from a different supplier and/or the package has a different part number from the supplier’s invoice.)
    However it works well for us and we can see exactly what is in stock at any time. It can be set up with minimum order levels and the system will prompt for the item to be reordered.
    Bob
