bobokines
Viewing 15 posts - 721 through 735 (of 760 total)
  • in reply to: Hygena dishwasher casing live ! #146633
    bobokines
    Re: Hygena dishwasher casing live !
    Something that you can check for yourself is the earth connection in the plug.
    If the machine is connected to an extension cable or a two way adapter, then that could be at fault.
    Any appliance that is not earthed correctly is fundamentally dangerous and should not be used until the earth fault is repaired. Should the appliance develop a serious fault in the future it could kill someone rather than just blowing the fuse.:zap:
    In theory the appliance will work without the suppressor but it is there for a purpose; to stop the appliance interfering with sensitive electronic equipment (including its own microprocessor in the timer unit) and should not be disconnected. The 125v reading is quite normal if the appliance is not earthed. Disconnecting the suppressor in this instance is not advisable as it is just covering the problem and not resolving it.
    Bob
    in reply to: Bosch Maxx WFO2466 sticking on programme #146501
    bobokines
    Re: Bosch Maxx WFO2466 sticking on programme
    I had an AEG machine the other day with a similar problem and it turned out to be the pressure switch sticking (level three) only after a heat pause. Of course I didn’t test the machine through a heat pause!
    in reply to: Multiple capacitor failure on creda C dryers #146517
    bobokines
    Re: Multiple capacitor failure on creda C dryers
    Do they use the same timer? It could be the length of reverse tumble and/or the duration of the pause.
    bob
    in reply to: AEG fault code CE ? #145595
    bobokines
    Re: AEG fault code CE ?
    I fitted one of these a few weeks ago. The twits at Connect Distribution warehouse thought it a good idea to put two cooker hinges inside the dispenser to save on packaging. It didn’t survive…
    Bob
    in reply to: Multiple capacitor failure on creda C dryers #146510
    bobokines
    Andy, That is definitely not true!
    The motor running temperature rises almost exponentially with an increase in capacitance. The correct rating capacitor should always be use to achieve the correct starting torque. Very important on condenser dryers that have a very short pause between reversing.
    Bob
    in reply to: Zanussi door seal replacement #146457
    bobokines
    Re: Zanussi door seal replacement
    There was a recent thread about this:
    http://www.ukwhitegoods.co.uk/modules.p … pic&t=6440
    Welcome to the Forums Mieleman. I am sure that your input will be much appreciated in hte future. Personally, I HATE working on Miele machines
    Bob
    in reply to: diplomat adp8132 reset codes #146356
    bobokines
    Re: diplomat adp8132 reset codes
    Thanks Craig. I have spent hours on this machine. Mostly getting it out of the housing! I really didn’t want to give up.
    Thanks again
    Bob
    in reply to: hotpoint intergrated dishwasher #146297
    bobokines
    Re: hotpoint intergrated dishwasher
    My own machine flooded the base the other day. Only problem was a saucepan handle restricting the top spray arm.
    The leak from the door seal run down the side directly into the base.
    As you said… Who designs this stuff?
    in reply to: Creda/WM type no spin. #145773
    bobokines
    Re: Creda/WM type no spin.
    This is SAD! I’m sitting in my hotel room on holiday, and I just had to log in to see the outcome of this one.
    Well done for sorting it
    Bob
    in reply to: Motor direction #145807
    bobokines
    Re: Motor direction
    It is possible but I can’t tell you off the top of my head. The brushes are above and below the centerline of the commutator and (I believe) the skew is in the direction of rotation.
    You don’t say what machine you are working on but, as I said earlier most machines spin clockwise.
    Many brushes have a “R” or an “L” printed on them, this is the direction of rotation on spin. However, which is which I am not sure.
    I’m off on holiday down the west country in about ten minutes and my wife is shouting at me to get moving. 👿 👿
    Dave… I’ll wave on the way past. :wave:
    in reply to: WMA Drum 5 yr Guarantee #141229
    bobokines
    Re: WMA Drum 5 yr Guarantee
    I would like to say “NO Merloni under five years old” but that would take away 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of my work. 😉
    I would dearly love to say “No Indes#it Dishwashers”.
    Bob
    in reply to: Motor direction #145805
    bobokines
    Re: Motor direction
    All Hotpoint machines have the dispenser on the left hand side but they all spin clockwise…
    If you look at the position where the dispenser hose joins the tub, it comes in at an angle (pointing toward the two oclock position) so a clockwise spin would tend to create negative pressure at that point.
    It also creates negative pressure at the pressure chamber orifice (I love that word).
    Bob
    in reply to: Whirlpool awm5125/1 will not start a program #145844
    bobokines
    Re: Whirlpool awm5125/1 will not start a program
    I’ve a feeling that an open circuit pump does the same thing.
    Bob
    in reply to: Creda/WM type no spin. #145768
    bobokines
    It’s not something really stupid like a ‘no spin’ switch on the front pushed in?
    I’m not sure if there is such a switch on this machine but it’s fooled me before.
    Bob
    in reply to: Motor direction #145802
    bobokines
    Re: Motor direction
    Sorry rushed that one in without answering the original question.
    Yes, reversing the polarity of the armature will reverse the direction of the motor. Thats exactly what the timer does to reverse the motor using the subinterval cams. (or a relay on the module on digital machines).
    In theory either the armature OR the field polarity can be reversed in order to reverse the direction of spin but on a washing machine it’s usually the armature that is switched rather than the field. This is due to the use of the half field tapping on the field to enable the superspin.
    MOST??? washing machines spin in a clockwise direction, however there are a few that spin anticlockwise.
    Hope that explains it
    Bob
