bobokines
Viewing 10 posts - 751 through 760 (of 760 total)
  • in reply to: Hotpoint BF41 Dishwasher #145068
    bobokines
    Re: Hotpoint BF41 Dishwasher
    I think the start button just overides the null position on the timer by energising the timer motor direct. As such it won’t stay in. I believe the timer is in the base of the machine and the program has to end once it’s started unless you [as an engineer] turns the timer manually by taking of the kick strip..
    You will find a wiring diagram on a piece of paper by the timer.
    Bob
    in reply to: UK Whitegoods Meeting 5 #127274
    bobokines
    Re: UK Whitegoods Meeting 5
    Dave. Please book me accommodation and meals for the two nights. Looking forwards to putting a few faces to names.
    Bob Okines
    Seniko Services
    in reply to: What do you love about this job ? #144826
    bobokines
    Re: What do you love about this job ?
    I think I was born with a spanner in my hand. I left school in 1977 and took an apprenticship with a local engineering company and then joined Hotpoint in 1987. In those days Hotpoint was a prestigious company to work for and I was really proud to be part of the team. God!! What went wrong!
    I have always loved mending things, meeting customers and driving. For me being a Hotpoint Engineer was a dream come true. It went a bit stale when Creda amalgamated and right downhill when Merloni took over. I was so sad that my dream job was no longer quite the same and I decided to get out when redundancies where being offered some three years ago.
    I tried a few other ventures but quickly realised that Service Engineering was my ‘thing’ and I quickly set up on my own with exactly the same principles that Hotpoint taught me in 1987. (I even wear a shirt and tie to work!)
    I haven’t looked back.
    in reply to: trigger board on Belling cooker #144685
    bobokines
    Re: trigger board on Belling cooker
    Thanks Dave. I have just seemed to fall in to cooker repairs without any formal training. Hence I have no wiring diagrams etc. I have always wondered what the trigger board controlled 😕 I suppose I could just follow the wires but I don’t want my customers to think I don’t know what I am doing.
    in reply to: wma pressure switch / service test problems #144269
    bobokines
    Re: wma pressure switch / service test problems
    Pressure switches rarely go out of calibration. They either work or they don’t! If it’s overfilling it is probably due to a blockage.
    Surely this is a classic case of “look for an associated fault” If you have just changed the door seal because of mould growth and had to remove and clean the dispenser due to the same, it implies that the sump hose/pressure chamber is blocked too.
    Bob
    in reply to: Bosch Dishwasher SGS66A02GB/17 #143943
    bobokines
    Re: Bosch Dishwasher SGS66A02GB/17
    Look for bad solder connection on heater relay on the module. There are other threads about this problem elsewhere on the forums.
    Bob
    in reply to: Dual Fuel Cookers #143744
    bobokines
    Re: Dual Fuel Cookers
    Thanks, I will probably work as I am at the moment and reject the calls.
    What about disconnecting a cooker on a bayonet fitting to move it out of the way to work on another appliance? I normally get the customer to move it.
    Bob
    in reply to: One for the Hotpoint specialists #143556
    bobokines
    Re: One for the Hotpoint specialists
    Look for an earth fault on the metal harness to cabinet clip by the door interlock. The weight of the drum changes during fill and the earth fault may not be showing until half full.
    in reply to: crusader 37667 condensing dryer #140410
    bobokines
    Re: crusader 37667 condensing dryer
    It’s the capacitor! I have been a Hotpoint/Creda Engineer for 15 years and I have seen this fool many engineers. It only happens with a large load when the machine is hot. Run it without the filter in place so that you can see the drum rotating. It sometimes only happens after 10 minutes and often trips the over temp stat.
    The motor has a very low starting torque when the capacitor first begins to fail. The problem exists when the (reversing) timer contacts switch over.
    The sequence is approx 3 minutes in forward mode (I think clockwise), one second off, 20 seconds reverse tumble with no heat, one second off, then 3 minutes forward with heat. The problem is the very short off period at the end of the reverse tumble. When the capacitor fails there is no time for the motor to stop during the off period and the drum carries on turning in the reverse mode with the heater on. Because the fan can only blow in one direction, the heater overheats and the TOC trips
    in reply to: AAAAAaaaaarrrrgggghhh!!!!!!!Zanussi door seal. #140047
    bobokines
    Re: AAAAAaaaaarrrrgggghhh!!!!!!!Zanussi door seal.
    I use a small 2-3 inch spring clamp available from B&Q. Holds the spring in place at the two o’clock position while you fight with the rest of it. A bit of washing up liquid helps.
    Hold the door seal against the inner drum and turn the whole lot together if you need to turn the door seal after fitting.
    The clamp is also brilliant as a third hand to help fit the seal to front panel retainer on whirlpool machines.
