bobokines
Viewing 15 posts - 76 through 90 (of 760 total)
  • in reply to: Van signwriting #241493
    bobokines
    Re: Van signwriting
    I really need to update my website as I changed my van over a year ago. However this is my signwriting…
    http://www.seniko.co.uk/
    Bob
    in reply to: HOTPOINT WF 860P #241519
    bobokines
    Re: HOTPOINT WF 860P
    Had exactly the same symptom on an built in Indesit washer dryer today. Although it showed F03 fault code (NTC) I was thrown by the filling at turn on symptom. The NTC tested out ok with the test meter.
    To be sure of the diagnosis I connected a van stock Hotpoint thermistor to the terminals to see what happened and the fault disappeared!
    I am going back next week with the correct NTC.
    Bob
    in reply to: A Quandry ? #241413
    bobokines
    Re: A Quandry ?
    Last one I had with that sort of problem was due to water leaking from the condenser/fan housing onto the module. Perhaps it’s the same problem and the water has now dried up and the fault cured itself…
    Until next time…
    Bob
    in reply to: NEFF S4340X0GB/20 #241025
    bobokines
    Re: NEFF S4340X0GB/20
    I recon a dodgy neural connection..
    Bob
    in reply to: Hotpoint wf540 spin direction #240916
    bobokines
    Re: Hotpoint wf540 spin direction
    johnnyj wrote:The ones with the welded tub spin anti clockwise.
    Thanks John.
    Bob
    in reply to: Hotpoint wf540 spin direction #240915
    bobokines
    Martin wrote:
    Dunno about the WF range but I know all the 95,WM and WMA’s spin anti-clockwise. After changing thousands of brushes, switching on and watching them lurch into life again! 😉
    You’re wrong there Martin. All the Hotpoint machines I have seen spin clockwise. Until perhaps the new WF range…
    Bob
    in reply to: Hoover HDV6 capacitor #240885
    bobokines
    Re: Hoover HDV6 capacitor
    LightingElectrical wrote:
    The symptoms are similar to relay pcb fault[starts ok sometimes but stops after a few minutes]. Timer and pcb have been eliminated by substitution.
    If the whole aplliance dies then it’s not going to be the capacitor. I would be looking for a mains supply problem, possibly the plug, socket or suppressor.
    Is this a condenser dryer? if so it’s worth checking the float switch. It’s a sod to get to as it’s a drum out job…
    Bob
    in reply to: CANDY CNL 135 #240775
    bobokines
    Re: CANDY CNL 135
    Check it on wash to ensure drum is reversing!
    Bet it’s only going one way… If so it’s a faulty relay on the board (or a dry joint that you have missed)
    Bob
    in reply to: zanussi wdj1294 prod no 914639003 #240434
    bobokines
    Re: zanussi wdj1294 prod no 914639003
    user manual is available here..
    http://www.serviceforce.co.uk/pdfs/U02329.pdf
    page 7 shows “dry button” this must be depressed otherwise the timer will quickly advance out of dry phase.
    Either the switch is faulty or your customer is… well you know!
    Bob
    in reply to: zanussi wdj1294 prod no 914639003 #240433
    bobokines
    I think the half load needs to be selected
    Bob
    in reply to: Neff integ dish no spray. #240004
    bobokines
    Re: Neff integ dish no spray.
    Whoops, didn’t read the original post properly. I thought it was the top spray not working.
    Bob
    in reply to: Neff integ dish no spray. #240002
    bobokines
    Before going down this line, check that you have diagnosed the fault correctly. Could still be a blocked metering hose!!!!
    Bob
    in reply to: Bosch Dishwasher SGS43T52GB/21 overheating #239192
    bobokines
    Re: Bosch Dishwasher SGS43T52GB/21 overheating
    I think this must have been a bad connection on the module.
    After checking all the wiring and checking the NTC resistance from the module end, the damn thing now works OK.
    Thanks again for the info.
    Bob
    in reply to: Bosch Dishwasher #239733
    bobokines
    had exactly the same problem a few months ago.
    http://www.ukwhitegoods.co.uk/modules.p … =bob+bosch
    ended up replacing the control module.
    Bob
    in reply to: best wash to get rid of suds???????? #239694
    bobokines
    Re: best wash to get rid of suds????????
    Nutradol air freshener. I discovered this purely by accident. The propelent used in aerosols will kill suds. smells nice too.
    Bob
