bobokines
Participanthelo_75 wrote: the only real cure is a new modified drum, part number 1703662
Can you tell me what is in the kit please
bob
bobokines
ParticipantRe: hotpoint WMA44N
Have you meggared the machine? An earth fault on the heater can cause this fault.
Bob
bobokines
ParticipantRe: prices of Hotpoint tools
bearig tool at Connect:
Bearing extractor tool kit this kit does not include the large bolt & Hardened washer
SRP: £349.42
Price:
1+ £282.51
Hotpoint HPT5600137 – from £4.97
Hardened washerHotpoint HPT5600138 – from £32.72
Bolt laundry😯
bobokines
ParticipantRe: £15.90 per month ??
Is the rate the same for all appliances?
I could not talk a customer out of paying this for a tumble dryer 😯
Bob
bobokines
ParticipantRe: Whirlpool OWI failure
ER! Model number?
could be 481227128407
That’s the black unit with the microswitch built in to the top. If its the optical one (transparent plastic) then you will probably need the model number.
Bob
bobokines
Lawrence wrote: How easy is it to fit ?
LawrenceTwo minutes… twist fit
Bob
bobokines
Optical Water Indicator.
It’s the device at the three o’clock position in the sump of the machine. If the error code points to this then believe it even if the device seems ok when testing with a test meter.
Sometimes the error code shows the fault as an OWI even if the device is the (microswitch) pressure switch system.
Some machines fill with a separate metering system (flow meter) but use this device as a backup safety water level test.
Bob
bobokines
ParticipantRe: Whirlpool DWF416 integrated Ikea dishwasher
have a read of this thread. I have used several Beko NTCs with no problems
Bob
bobokines
ParticipantRe: hotpoint wm74n keeps washing
not something silly like the hoses the wrong way round? It will stick on first rinse on synthetic cycle if the appliance does not cool down.
Bob
bobokines
ParticipantRe: AEG washer syphon tube
Thanks boys. Still not sure why it’s not available through the normal outlets though.
Cheers
Bobbobokines
ParticipantRe: How long do Hotpoint guarantee their repairs for?
hotpnt wrote: sounds like someone was after some extended warranty comission!
Makes you wonder how much commission they get? I had one customer today that has been phoned back twice to see if they changed their minds after refusing the warranty deal…
Bob
bobokines
ParticipantRe: Looking to buy a a Pocket PC or Smartphone?
Has anybody tried to use Quickbooks through their PDA yet? I believe the latest version of Quickbooks supports Windows Mobile.
If it works it would be sensible to upgrade to the latest version as I use quickbooks for my accounts.
Bob
bobokines
I use an O2 XDA Exec.
It has its own keyboard. I always use a bluetooth headset and rarely need to write anything down on paper.
It is a bit limited on built-in memory and the calendar function has to use the built-in RAM and cannot store to the SD card. The lack of memory means that it can only carry 6 months or so history on the calender. This is the only real problem that I have encountered.
Bob
bobokines
ParticipantRe: creda T620CW
If the capacitor is open circuit or low capacitance then the symptom would be that the drum will start with a push, however if the capacitor is short circuit then the motor will simply lock up…
Bob
bobokines
ParticipantRe: Odd computer thing
ALT+G is a hotkey to google…
Not sure why it should do it when keying a G in password though…
Bob
