bobokines
Viewing 15 posts - 46 through 60 (of 760 total)
  • in reply to: Brandt Dishwasher similar to Hotpoint BF41 hinge assy #250836
    bobokines
    Re: Brandt Dishwasher similar to Hotpoint BF41 hinge assy
    Thanks Chris…
    I am sure I have been here before. I seem to remember I couldn’t find the part before.
    I’ll order the kit and see what turns up.
    Thanks again
    Bob
    in reply to: Brandt Dishwasher similar to Hotpoint BF41 hinge assy #250834
    bobokines
    Penguin45 wrote:Curvy plastic thingy?
    Er…No Curvy metal thing…
    It’s the bit on top front corners that the door spring adjustments clip onto
    Bob
    in reply to: New tool for dealing with water escapage #250515
    bobokines
    Re: New tool for dealing with water escapage
    andy_art_trigg wrote:
    Bob: I haven’t seen the product you use Bob, I would need to know more about them before being able to compare them properly. Have you seen the video test that I did? Does the product you use do a similar job? Will it soak up to 5 L?
    It’s only really a very absorbent sponge. It will hold its own volume of water… About half a litre.
    It’s great for spills and for sucking out the last bit from a dishwasher or emptying a flooded base.
    good for cleaning the car too!
    Bob
    in reply to: New tool for dealing with water escapage #250508
    bobokines
    I use these super soaker blocks that are available at my local ‘pound shop’
    http://www.choiceful.com/choiceful-id-1 … Block.html
    They are brilllant. They can be reused and will soak up their own volume in water.
    Probably the most useful tool I have.
    Bob
    in reply to: Brandt Dishwasher #250240
    bobokines
    It has probably taken out the overtemp stat on the heater (resettable) this will cause the appliance to stick on heat pause with the circ motor running but with the timer motor off..
    Bob
    in reply to: indesit IDL500 top spray feed seal #250356
    bobokines
    Re: indesit IDL500 top spray feed seal
    Thanks Jim. That was my guess too
    I will order the part and see what turns up
    I’ll let you know
    Thanks again
    Bob
    in reply to: aeg dishwasher leak into base #250105
    bobokines
    Re: aeg dishwasher leak into base
    Last one I had turned out to be an intermittant drain pump failure. Took four visits to resolve the problem 😳
    Bob
    in reply to: When to do a job right #250083
    bobokines
    Re: When to do a job right
    smartin wrote:481931039692 whirlpool jubilee clip kit various sizes perfect for cylinder heaters
    smartin
    Do you kno how many clips you get in this kit please?
    Bob
    in reply to: bosch dishwasher leaking from water tank SGS66A02 GB17 #249922
    bobokines
    Re: bosch dishwasher leaking from water tank SGS66A02 GB17
    eastlmark wrote: TBH I dont mess about cleaning those floats anymore, just fit a new one.497570
    Mark, why not clean them? I have cleaned hundreds and not one failure. Surely there’s not enough profit in supplying a new one to justify the cost to the customer.
    Bob
    in reply to: Magnetic Motors #248942
    bobokines
    Re: Magnetic Motors
    this is a bit too heavy reading tonight after a few glasses of Grouse, but here is the patent submitted by Askoll for a device to control direction on a synchronous permanent magnet motor…
    http://gauss.ffii.org/PatentView/EP1351376
    Perhaps this in incorporated in the motor somewhere.
    Bob
    in reply to: Hotpoint WMA61P drum paddle which one do i need? #248904
    bobokines
    Re: Hotpoint WMA61P drum paddle which one do i need?
    on this subject. What’s the difference between version 2 and 3
    Bob
    in reply to: Magnetic Motors #248935
    bobokines
    Re: Magnetic Motors
    ER! Sorry M1 That’s totally wrong.
    An AC motor with only two terminals can NOT be reversed by changing polarity of the terminals.
    P45… I think it’s down to the design of the impellor. If you look at the impellor it has a near 270 degree free movement on the shaft. On the big synchronous motor on the whirlpool machines, I noticed that the free movement is much looser in one direction than the other.
    would love to know the definite answer to this one myself, so anyone else with any ideas please chip in.
    Bob
    in reply to: proline ef9000 cooker switch #247613
    bobokines
    Re: proline ef9000 cooker switch
    thanks everyone.
    Bob
    in reply to: anybody got a wiring diagram for a Hotpoint wma34? #246960
    bobokines
    Re: anybody got a wiring diagram for a Hotpoint wma34?
    Thanks Jim. You are a star 😀
    Bob
    in reply to: Bosch SRS43C12 pathetic spray #245954
    bobokines
    Re: Bosch SRS43C12 pathetic spray
    HI Mark, Ihad a built in Neff dishwasher (S4443b6gb/01) the other day with the same symptom.
    The customer had told me that he had taken some broken glass out of the drain pump and I thought that perhaps some glass had damaged the wash motor impellor.
    I went back with a new impellor and two hours later was still scratching my head.
    I stripped the damn thing down to its shell but found no problem with the impeller and no blockages anywhere. I can only assume that the diverter valve is at fault…
    I did notice that there is a tacho feedback on the motor. Anyone any idea what that’s for?
    Bob
