aqua_serve
Viewing 15 posts - 1 through 15 (of 110 total)
  • in reply to: Bosch HHF113BR0B/04 oven #490467
    aqua_serve
    Cheers Merv,
    You’ve taught me something therte. Really appreciate it!
    in reply to: Smeg DF612 service manual. #488106
    aqua_serve
    Cheers Dave,
    I really appreciate you sending the service manual. I was hoping that it’d have electrical diagrams including the layout of the PCB.
    I’ve got a customer who tried a DIY repair by replacing a blown board. The live/neutral connector had melted and the board was destroyed. He didn’t take a picture of which way round they were inserted into the board and threw the melted plug away. I’m off to refit the new PCB he has bought but wanted to be sure I got the wiring correct when I fit spade connectors to them.
    in reply to: Smeg DF612 service manual. #488103
    aqua_serve
    electrofix wrote: check the model it should have letters after the numbers
    Hi Dave, it’s a DF612 SE.
    Mark
    in reply to: Indesit DIF 16B1 UK (769991025023) #487892
    aqua_serve
    electrofix wrote:
    ok lets tell you how i did it
    goto
    https://parts.indesit.co.uk/
    put in your ind code 769991025023
    that will bring up part diagrams
    click on pic of the door and you will see dispenser is part of door inner
    select part and click through gives you part no C00386638
    indesit’s price £117
    Dave [h=2][/h]
    Cheers Dave, you’re a star!
    in reply to: Lamona LAM8605 recirculation motor #485231
    aqua_serve
    Cheers guys, really appreciate your assistance!
    in reply to: Hotpoint WMTL80 top loading washing machine. #479734
    aqua_serve
    Hi Dave,
    I didn’t try the heater earth as it happens but can do!
    The cycle stops and the dial just keeps clicking around with the mains light flashing once a second.
    in reply to: LTF 11M132 C UK wiring harness #477631
    aqua_serve
    Hi Dave,
    Thanks for your reply and apologies for the delay in returning a reply, the number is 869990830020.
    Yours,
    Mark
    in reply to: Hoover HBTDW H7A1TCE-80 service manual #477216
    aqua_serve
    Thanks Dave, I appreciate your assistance.
    in reply to: Bosch SPS40E32GB/40 Dishwasher. #476913
    aqua_serve
    Cheers Dave, most helpful, I’ll give that a shot and see where it leads me.
    in reply to: Bosch SPS40E32GB/40 Dishwasher. #476911
    aqua_serve
    Hi Dave,
    Thanks for the reply, the pump doesn’t seem to want to operate once in position with the pump cover refitted. You are correct in how I tested the pump, when connected to it’s harness it worked flawlessly!
    Mark
    in reply to: WDX8543130W Beko washer drier. #456957
    aqua_serve
    Re: WDX8543130W Beko washer drier.
    Thanks Dave, much appreciated.
    Do any of you guys have a service manual for this machine?
    Mark
    in reply to: WDX8543130W Beko washer drier. #456955
    aqua_serve
    Thanks Dave,
    That part number doesn’t seem to exist online. Do you have a part number for the board supplying the power to the display board?
    Mark
    in reply to: Bosch WAE24167GB/85 #456819
    aqua_serve
    Re: Bosch WAE24167GB/85
    Thanks Dave
    You’re a star!
    in reply to: De Dietrich FW4827E35 element #444347
    aqua_serve
    Re: De Dietrich FW4827E35 element
    Thanks Dave, that was the source of my part number, just saw there were others there, but thought this was the one.
    Your help is much appreciated.
    Mark
    in reply to: Bosch SGS43A52GB/35 slow emptying #437570
    aqua_serve
    Re: Bosch SGS43A52GB/35 slow emptying
    Cheers Martin.
    I really appreciate your assistance.
    Mark
