bobokines
Viewing 15 posts - 286 through 300 (of 760 total)
  • in reply to: AEG Washing machine Flashes C7 #202453
    bobokines
    Re: AEG Washing machine Flashes C7
    treat yourself to the TDS disc. It’s packed full of info on all Electrolux machines. It is available from Connect at a very good price.
    DSTDVD2006V2 £20.00 and it’s a stock item.
    Bob
    in reply to: AEG Washing machine Flashes C7 #202451
    bobokines
    By the way… welcome to the mad house!
    Don’t forget to post the full model numbers and (if possible) the PNC code
    Bob
    in reply to: AEG Washing machine Flashes C7 #202450
    bobokines
    Dave, you may have rectified the fault without realising. eg perhaps a bad connection to the heater. Unless you reset the control it will still show the error code,
    Quote from the ‘known error code’ page..
    “Some of these faults are locked in and will return even if machine is disconnected, the only way to clear them is to run the test programme. Hold in Pre wash and soak button while turning rotary knob to gentle spin”
    Bob
    in reply to: Kuppersbusch EEB9600.0MK76 Thermal overload #202371
    bobokines
    Re: Kuppersbusch EEB9600.0MK76 Thermal overload
    Thanks again Dave
    in reply to: Kuppersbusch EEB9600.0MK76 Thermal overload #202369
    bobokines
    Thanks Dave, any idea who might stock one?
    Bob
    bobokines
    Re: Getting the belt on the tension pulley – Hpt condenser d
    I’ve done two or three 9 rib belts without a problem.
    I wonder if they might be actually easier to fit than the 7 rib…
    Are they perhaps a weaker belt with more stretch and the extra width is to give a higher surface area to give a better friction for less tension???
    Bob
    bobokines
    Price is a bit steep at £29.00
    I normally manage to get the vented dryer belts on without too much problem. A bit of elbow grease and a deep 13mm socket over the shaft helps.
    Bob
    bobokines
    There’s another version of this topic going around somewhere…
    My tool is so simple. I use a junior hacksaw with the blade removed. Use the handle of the hacksaw as a hook and pull the belt over the jockey pulley. It takes seconds and it’s a tool already in your tool box.
    Bob
    in reply to: Hoover HW 6316MUK No Spin #202174
    bobokines
    Re: Hoover HW 6316MUK No Spin
    Check that the machine tumbles in both directions. Very common to have a faulty relay (or solder connection) on the board.
    Bob
    in reply to: A Dire Warning……. #201962
    bobokines
    Re: A Dire Warning…….
    2. Make great foot-warmers.
    :rotl:
    in reply to: hotpoint wd64 #201864
    bobokines
    Re: hotpoint wd64
    Check for a chaffed wire on the wiring harness by the motor..
    Bob
    in reply to: Hotpoint VTD00 Non stop timer #201691
    bobokines
    Re: Hotpoint VTD00 Non stop timer
    Did you meggar the machine? I don’t know the wiring for this machine but it might be switched in the neutral and an earth fault may be causing the fault.
    Bob
    in reply to: Servis M3025 Sole Motor #201151
    bobokines
    Re: Servis M3025 Sole Motor
    It’s early!
    in reply to: Servis M3025 Sole Motor #201149
    bobokines
    Have you checked the pressure switch or an earth fault on the heater?
    Bob
    in reply to: Testing or Bypassing Door Interlock #200480
    bobokines
    Re: Testing or Bypassing Door Interlock
    andy2 wrote:What if you attend a machine for another fault and discover that the interlock has been bypassed previously by someone else?
    Had one today. The machine had been in use for a year and had been purchased from a local dealer (ha!). The fault today was worn brushes and a noisy pump. The interlock had been bypassed by removing the two amp tags and twisting the bare wires together and insulating with a piece of gaffer tape 😯 .
    The timer was blown so I wrote the machine off. Much to the upset of the 70 year old customer… but to the delight of her nephew who was looking after her.
    He (the nephew) is off to the local dealer tomorrow with his baseball bat 😀
    Bob
