bobokines
ParticipantRe: Hotpoint DW BFI620 Hinge
Dave, Connect shows that part as a RH hinge. Is this correct?
Bob
bobokines
Thanks mate. 😀
Bob
bobokines
ParticipantRe: Hotpoint BWM129 Built in Washer
Thanks Jim. I believe the leak was from the blocked fab conditioner compartment. However, as is the norm, it wont leak when I’m watching it.
How is your Mum by the way?
Bob
bobokines
ParticipantRe: Samsung Q1636S w/m
The motor will be “star” connected. ie all the coils will be connected in a star configuration with the central joint insulated and not accessible. The only test on the motor will be a coil resistance check and an earth check. All terminals should have the same resistance relative to any other terminal. If all the resistances are the same (within a few percent) and there is no earth leakage then there is unlikely to be a problem with the motor.
The circuit board is encapsulated in a resin which will make component testing very difficult. Be very careful, I believe that the electrolytic capacitors on the board can hold a charge for a long time.
Good luck
Bob
bobokines
It’s a three phase motor that is fed by an invertor. The frequency of the invertor will determine the motor speed. (Three phase motors have a much higher output torque than a single phase motor with the same size stator/rotor assembly) Why the three wires from the tacho…? could it be a three phase output? not sure.
Bob
bobokines
ParticipantRe: hotpoint 9410
The stator from a wash motor will fit if you can still get a wash motor.
Bob
bobokines
ParticipantRe: Need explaination on C/D parts
The relay on condenser dryers is a latching relay that ensures that someone has to be present to turn the appliance on. This is due to the large loading door which is large enough for a child to climb in.
Bob
bobokines
ParticipantRe: Bosch washing machine door seal
Don’t forget that we need a model number to help with these enquiries…
You’re not alone in having difficulty fitting the retaining spring. Our trade forum has several similar posts as even a long served engineer can have difficulties with some machines.
The normal answer here, without special tools, is to get someone to give you a helping hand. Get a friend to hold it at the top whilst you fight with rest of it.
If you need help, use our Repairs@ service to find a local engineer.
Remember… Power off before attempting any repair. :plug:
Bob
bobokines
ParticipantRe: Cookers 05-600412 cooling fan
Thanks Dave, I didn’t realise they are so reasonable price.
Bob
bobokines
ParticipantRe: Zanussi ZWX1606W Pressure switch
This machine is pretty well protected by the electronics and throws an error code and stops dead whenever it sees a fault. I’m quite happy in this situation to leave it working.
However I understand your sentiments here. It’s usually best in my experience to leave the machine disconnected with a “do not use” notice attached. It’s the only way to cover yourself.
Bob
bobokines
Thanks mate. I have tapped it with a screwdriver and brought it back to life so it might last a few washes.
Bob
bobokines
ParticipantRe: Cookers 02600301 Oven stat
Thanks Dave
bobokines
Thanks Dave.
Don’t suppose you can find a supplier for this 😉
You had a few days rest?
Bob
bobokines
ParticipantRe: Whirpool AWM320
Translates as “That one would have to put it in good books of the Roberto”
Still nonsense.
Bobbobokines
ParticipantRe: Whirlpool AWM 8123/3 washer – heating element
WARNING
Sorry lads… don’t do this!… I got a recall today to a flooded floor.
The Hotpoint heater fell out after one wash. The rubber is just not long enough to create a tight seal.Bob
