bobokines
Viewing 15 posts - 616 through 630 (of 760 total)
  • in reply to: Creda 37747 Condenser dryer #153325
    bobokines
    Re: Creda 37747 Condenser dryer
    The pair of stats must always be replaced as a pair. 1701583
    The control stat is at the twelve oclock position above the door access and trips at 58 degrees.
    The usual reason for the one shot stat failing is the customer opening the door during the drying cycle, however it usually takes more than a week for this to happen so I would investigate further.
    There is a lot of information on this site about this problem. Have a probe about using the search feature. You’re not alone…
    Bob
    in reply to: Mobile phones… continued #151422
    bobokines
    Re: Mobile phones… continued
    I use an XDA11 (o2) It’s brilliant. It’s a ‘smartphone’ that I use as a PDA, Telephone, Calculator, Camera, Sat Nav… I can even browse the UKW website in my lunchbreak.
    … Lunchbreak? What’s that?
    Bob
    in reply to: Market Research #148627
    bobokines
    Re: Market Research
    I won’t mind being a bit more pushy, the point being that the survey may not be unbiased if only a particular type of person is willing to contribute.
    Many years ago, a done a similar survey on behalf of a university student who needed to do a survey for their coursework. I had 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} success when I asked my customers if they would be willing to answer a few questions. However, I seem to have hit a blank with the telephone survey.
    I’ll keep trying
    Bob
    in reply to: Market Research #148625
    bobokines
    Re: Market Research
    Kevin, I am having a nightmare trying to get anyone to participate in the survey.
    I’m probably not pushing this very well but I have had a very negative response when I ask for people to help out. It seems that people don’t like the thought of someone phoning them to ask questions. If I was asking them to fill in a form while I was there I don’t think there would be a problem. I have only one person willing to participate and five in a row that were positively against it!
    It makes me wonder if you will be getting a true picture if the survey is only taken up by a particular type of person.
    How are the rest of you guy’s getting on?
    Bob
    in reply to: Calling UKW Refrigeration Engineers #151828
    bobokines
    Re: Calling UKW Refrigeration Engineers
    It is early 😉
    Bob
    in reply to: Calling UKW Refrigeration Engineers #151826
    bobokines
    Dave, Is there any chance of a bit on about adequate cabinet ventilation. I see loads of Mistrals with blocked condensers where the dog sits in front and blocks it up with dog hair. The sympton is the freezer runs, cycling on the compressor overtemp stat and usually runs at -12 to -15 degrees (warm enough to bring on the overtemp light but not obvious where the fault is)
    I don’t do refrigeration appliances now but I do know this is a very common fault that can easily be rectified by the customer without an engineer visit.
    I think the sticky is brilliant. :tup: Just the right length without too much high tech talk.
    Small typo. Second to last paragraph, second to last line. “cause” spelt “caus”
    Bob
    in reply to: Trade Suppliers #152026
    bobokines
    Re: Trade Suppliers
    Seme Nedis Ltd
    Chandos House
    School Lane
    Buckingham
    Bucks
    MK18 1HD
    01644 484000
    FAX 01664 563976
    Suppliers of spares to the trade.
    in reply to: Larger brain required. #153178
    bobokines
    Re: Larger brain required.
    I don’t know this particular machine but the control unit is the same as wm51, wm61 etc. The motor reversing is done solely on the control unit and I would have suspected the timer as well.
    It it a GDA motor or a FHP motor?
    Does the motor run correctly on the forward tumble with a nice ramp up to spin or does it ‘lurch’ into spin?
    If it doesn’t sound right it might have one faulty field coil, this might only show up in reverse tumble. Check that both coils have the same resistance.
    I’ll put my thinking cap on as I am sure I’ve had this problem before.
    Bob
    in reply to: Indesit W1035WG blows trip #152828
    bobokines
    Re: Indesit W1035WG blows trip
    If the heater has a low insulation resistance it will still heat up. If the motor has a low insulation resistance it will still rotate, but if you add the two low insulation resistances together it may be enough to trip an RCD.
    Your test meter will sort it out for sure.
    Bob
    in reply to: Creda T322VW can i retrofit with belt and pulleys? #152750
    bobokines
    Re: Creda T322VW can i retrofit with belt and pulleys?
    Surely that belt number is for an early 5KG model!
    Bob
    in reply to: Hotpoint WMA63 #152909
    bobokines
    Re: Hotpoint WMA63
    Jim, can you send me a copy of that please to Bob@seniko.co.uk .
    Cheers
    Bob
    in reply to: Indesit W1035WG blows trip #152826
    bobokines
    If you have just changed the bearings and drum support, did you inspect the heater for damage when you had it out?
    Bob
    in reply to: Hotpoint BS41B Cooker #152936
    bobokines
    Re: Hotpoint BS41B Cooker
    Thanks Dave, I’m sure that’s the ones, if not I will improvise. The customer threw away all of the door fixings when the glued front glass fell to bits. She then decided to get it fixed. Silly old Sod! I have sussed out all of the other bits.
    Thanks again
    Bob
    in reply to: Indesit W1035WG blows trip #152824
    bobokines
    How can you do a day’s work without a meggar?
    Sorry Mike, but Martin’s right, there’s no guesswork here, you just can’t assume that a machine is safe to plug in without a meggar test!
    Bob
    in reply to: smeg intergrated dishwasher fault codes #152774
    bobokines
    Re: smeg intergrated dishwasher fault codes
    Had the same today. Mine was a Teka branded model. It was a blocked metering hose system. This can sometimes be cleaned with your trusty syringe and a length of pressure hose:
    Remove the black non-return valve under the filter then suck and blow some water through the pipes. However, it woiuldn’t work for me today and I had to strip it down as the gunk was in the metering chamber inside the right hand side wall.
    Bob
