bobokines
Viewing 15 posts - 631 through 645 (of 760 total)
  • in reply to: Safety Issue on Hotpoint Dishwashers #147737
    bobokines
    Re: Safety Issue on Hotpoint Dishwashers
    I went to one today (Indesit D61UK) and made a point of checking whether there were any live terminals in reach when the door was open and, it appears, that the door switch isolates all of the accessible components. The test was not very scientific, just the use of a no contact volt tester in the areas I could reach.
    Bob
    in reply to: Safety Issue on Hotpoint Dishwashers #147731
    bobokines
    Martin, I am not trying to reduce the seriousness of this situation, only to explore the problem. If the exposed wires are isolated from the mains when the door is open, the British Standard Finger Test, which only refers to LIVE teminals may not be applicable. I really do feel strongly about this issue, which is why I have continued this thread, however we must have the ammunition and the correct information before taking it further.
    Bob
    in reply to: Safety Issue on Hotpoint Dishwashers #147727
    bobokines
    Personally I think it unforgivable that there is access at this point for small fingers. However, if the uninsulated terminals are not live when the door is open, it might not contravene any safety rules. Don’t like it anyhow!
    Bob
    in reply to: Squeeking WP Washer #152363
    bobokines
    Re: Squeeking WP Washer
    Thanks Steve, I will do just that. I’ll let you know how I get on.
    Sorry Dave, service number is 857081415200.
    Bob
    in reply to: Safety Issue on Hotpoint Dishwashers #147725
    bobokines
    Does someone have a wiring diagram for these machines to see if the exposed wires are live with the door open?
    Bob
    in reply to: Safety Issue on Hotpoint Dishwashers #147719
    bobokines
    Just to resurrect this thread, I called to an Indesit slimline dishwasher yesterday without any protection behind the kickstrip.
    Model D41UK S/n 306097250
    This photo (sorry it’s a bit dark) was taken from the floor with the door open. This machine has never been worked on before.
    http://www.seniko.co.uk/images/image_00008.jpg
    Anyone else seen these? I’m beginning to doubt myself.
    in reply to: dw909s #152283
    bobokines
    Re: dw909s
    In my experience, if there is water on the floor and NOT in the base then it’s due to a blocked, split or restricted spray arm.
    Bob
    in reply to: Slight Odour Left on Glasses (Bosch Dishwasher) #152134
    bobokines
    Re: Slight Odour Left on Glasses (Bosch Dishwasher)
    Be very careful if you have a go at taking the dispenser out. The edges of the stainless steel door panel are razor sharp.
    Bob
    in reply to: Slight Odour Left on Glasses (Bosch Dishwasher) #152131
    bobokines
    If you are putting the tablet in the tub with the plates then it’s likely that the detergent is being washed away in the pre-rinse.
    You have two choices; either repair the dispenser or put the tablet in before the main wash cycle, not the pre-rinse. This entails opening the door during the wash which is not advisable. There are two reasons for this;
    1)The door switch is not designed to switch the heater current and therefore over a prolonged period the door switch could fail.
    2)The vacuum created by the action of opening the door can fool the water level system and cause fill problems.
    The dispenser not opening problem is usually the dispenser itself but it could be the control module at fault. It will need an engineer to check to be sure.
    Bob
    in reply to: aeg kdwi d/w #152188
    bobokines
    Re: aeg kdwi d/w
    OK… Are the part numbers available on the TDS disk or do I keep guessing???
    Bob
    in reply to: aeg kdwi d/w #152186
    bobokines
    Re: aeg kdwi d/w
    I like to complete as many calls as I can on the first visit. If there is not a universal kit and cleaning it out clears the problem, then how is it viable to make an incomplete call just to go back with go back with a special kit?
    :con:
    Bob
    in reply to: aeg kdwi d/w #152182
    bobokines
    Re: aeg kdwi d/w
    Is it “One kit fits all”? or are a there several kits. If it is a universal, do you have a part number please.
    Bob
    in reply to: aeg kdwi d/w #152180
    bobokines
    Re: aeg kdwi d/w
    What exactly is this kit and why is it needed? I have seen loads of Zan dishwashers with blockages but I have never been unable to sort them out. Surely the time taken to fit the kit would be the same as to clean out the old one. Or am I missing something?
    Bob
    in reply to: Ignore List! #152145
    bobokines
    Re: Ignore List!
    You know you’ve made it in life when you’re on an ignore list 🙄
    Wow!
    Bob
    in reply to: Hotpoint 9949 Washer/Dryer Fault #151957
    bobokines
    Re: Hotpoint 9949 Washer/Dryer Fault
    I love a happy ending 😀
