bobokines
Viewing 15 posts - 676 through 690 (of 760 total)
  • in reply to: hoover motor tacho magnet #150805
    bobokines
    Re: hoover motor tacho magnet
    I have tried to take them off an old motor but they tend to just crack. Shame to dump an otherwose good motor for the sake of a tiny bit of plastic.
    Bob
    in reply to: Resetting Zanussi PCB/Timer #150799
    bobokines
    Re: Resetting Zanussi PCB/Timer
    :wave:
    Welcome back. sun tan?
    Bob
    in reply to: Resetting Zanussi PCB/Timer #150796
    bobokines
    Sounds like a pressure switch or chamber problem.
    Bob
    in reply to: WMA wire chafe #150737
    bobokines
    Re: WMA wire chafe
    These problems only appear AFTER a Hotperloni engineer(ha) has been at work on these machines. It looks like they need some training. 😉
    Bob
    in reply to: Stoves 058552079 indicator disk #150726
    bobokines
    Re: Stoves 058552079 indicator disk
    Thanks Dave, phone call in the morning I think.
    Bob
    in reply to: URGENT WARNING #150452
    bobokines
    Re: URGENT WARNING
    :boops:
    in reply to: URGENT WARNING #150450
    bobokines
    Re: URGENT WARNING
    Have you seen this one?
    http://www.veryfunnydownloads.com/downl … s/DODO.MPG
    Bob
    in reply to: Zanussi pressure pots #150124
    bobokines
    Re: Zanussi pressure pots
    Bit confused here, are we talking about washing machine pressure chambers or dishwasher matrixes? 😕
    I find the best way of cleaning the dishwasher matrix is to take it off the machine, take it into the garden with a bowl of water. Take the valve coils off. Then squirt warm water through the valve openings with a syringe and give the whole thing a good shake. Be prepared to get wet!
    I make a little ‘ bottle brush’ from a length of electrical cable with an inch or so of insulation cut back and the copper conductors frayed out. This can be used to get to hard to reach areas.
    Keep at it until all traces of black gunge has gone. Otherwise you will be back within a few months to do it again.
    Washing machine pressure chambers I clean through the pressure hoses with hot water from a syringe. Keep sucking and blowing until the water runs clean.
    A bit of diluted chlorine bleach helps in both cases
    Bob
    in reply to: Identifying Date Codes and Serial Numbers #150358
    bobokines
    Re: Identifying Date Codes and Serial Numbers
    Here’s the Hotpoint date code list in printable format. Thanks to Jim for the info.
    http://www.seniko.co.uk/pdf/hotpoint_date_code.pdf
    Bob
    in reply to: Hoover date codes ??? #150283
    bobokines
    Re: Hoover date codes ???
    Thanks Jim.
    Bob
    in reply to: WMA44 no motor action #150241
    bobokines
    Re: WMA44 no motor action
    Often caused by Hotperloni engineers not tying the harness correctly following a drum change. The wires chaff on the lower concrete balance weight.
    Bob
    in reply to: Hoover date codes ??? #150280
    bobokines
    Jim, can you post the Hotpoint date codes please.
    Bob
    in reply to: BC145 D/w on fire #149907
    bobokines
    Re: BC145 D/w on fire
    I had a free standing one today (sorry no model number) that had caught fire and tripped the RCD. This was only 13 months old. I sent the customer to Hotpoint with the hope that they will take responsibilty.
    The motor was burned out, there is a black hose above the motor that had melted and squirted water everywhere. The plastic unit on the bottom of the tub that holds the motor mount had completely melted. The resin unit has melted and distorted. I didn’t investigate further to find the reason for the fire but the base looked as if it has been wet for a while. The machine is leaning forward by about 10mm top to bottom.
    All in all, its a bit of a sh#t machine really. (Under-statement or what!!)
    Bob
    in reply to: Hoover WDM130 overfilling #150207
    bobokines
    Re: Hoover WDM130 overfilling
    When testing for air leaks it’s much easier to test for a vacuum rather than a positive pressure. If you seal one end of the pipe with your finger and suck on the other end to try and create a vacuum, you can usually ‘feel’ a drop in pressure on your tongue.
    Don’t suck on a pressure switch though as you may damage it and alter the calibration.
    Bob
    in reply to: Hotpoint WMA61 #150189
    bobokines
    Re: Hotpoint WMA61
    Cant you see any marks on the edge connector tracks where the plug was before?
    Bob
