bobokines
ParticipantRe: Bosch condenser dryer noises
Thanks Martin
bobokines
ParticipantRe: Belling E51h1 base element
Cheers Dave.
I’ll get the other numbers :rolls:
Bob
bobokines
ParticipantRe: bendix dishwasher
Do you have a model number?
Bob
bobokines
ParticipantRe: smeg dishwasher Di612c overfilling
Thanks Dave. I’m only going to get one hit at this one. It’s one of those instances where the house has been sold with the appliances and the machine has broken down before completion…
Bob
bobokines
ParticipantRe: ctd00
Once the relay has engaged it is basically not involved in the reversing circuitry. I would go for the timer.
Bob
bobokines
ParticipantRe: Hoover dishwasher D7610 Upper spray arm.
The only number I can find is the D7610 on the facia. The rating plate has long gone…
The CAN06011662 spray arm kit contains three parts so it might be interchangeable. Do you know if the top basket part number stays the same throughout the three versions?
Bob
bobokines
ParticipantRe: Hotpoint CTD40P door switch actuator
Thanks Jim. That was my guess.
Chhers
Bob
bobokines
ParticipantRe: WD71P E30 PCB blown
Check for a sock in the drum!
Bob
bobokines
ParticipantRe: cookers 05600407 thermal cutout
Steve, the part I need is for the main oven. It’s a 140C TOC
Bob
bobokines
ParticipantRe: Hotpoint WM71
If it was a tacho problem, it would show E30 and abort the spin within a second or so.
My guess is a dodgy triac on the board. If it has been bodged by another repairer, I would leave well alone. You could be digging yourself a huge hole..
Bob
bobokines
ParticipantRe: Indesit W123UKBG Door seal
Thanks Jim 😀
bobokines
ParticipantRe: jackson dishwasher
Can’t really remember to be honest. It must be 20 years ago that I trained on these machines. I think the pipe that I am refering to is the top of the pressure chamber.
Bob
bobokines
Going back over twenty years now, so I might be mistaken…
Under the filter at about 11 o’clock position, there is a two inch high tube sticking up with a small hole through the top.
If I remember correctly, you need to suck any water out of that pipe. Best done with a drinking straw and a small syringe. You can also use a trigger spray head (from a bottle of kitchen cleaner etc) .
Good luck
Bob
bobokines
ParticipantRe: whirlpool leaks
well well. Who says you can’t learn new tricks!
Thanks boys
Bob
bobokines
When you say remove it, do you mean from its storage postion?
Can’t see how it makes a difference…
Bob
