JOHN CLARKE
ParticipantRe: Hotpoint Dishwasher FDW50P
Thankyou Iadom, I will order that one. I looked on the Hotpoint spares site they tell us there are two then ask us to “VIEW” below but there is no view below.
JOHN CLARKE
The Model No is actually DWF50P,
JOHN CLARKE
I have 2 module part Nos, they are C00094686 and C00143207, I do not know which one to order.
JOHN CLARKE
ParticipantRe: WMA 31 bearings and spider
If you give the spider screws a good hammering on their heads it seems to loosen them, give it a firm and steady turn suddenly they unscrew, if it does’nt work hammer it again, be careful you don’t break your torx bit in situ though.
JOHN CLARKE
ParticipantRe: Whirlpool Dishwasher ADG7540
Well I checked all hoses suction and discharge, cleaned spray arms and filters checked water level device, no problems found, same fault. Removed Ceset motor, fitted a refurbished Askoll motor, ran perfectly,when the motor stops the water valve does not operate so its not the water level device at fault. Work that one out for me, I ran the Ceset motor in my garage it runs perfectly.
JOHN CLARKE
Thanks, I’ll have a good look around the hoses.
JOHN CLARKE
ParticipantRe: HOTPOINT FDW80G STUCK IN DEMO
Thanks Tim,
I think the latter suggestion seems more appropiate, I’ll try pressing buttons afterwards, thanks again.JOHN CLARKE
ParticipantRe: Indesit Module
Thanks for your reply A1engineer, I thought that might be the case, I wonder if EMW will programme it for me, I’ll have to ring in the morning.
JOHN CLARKE
ParticipantRe: WHIRLPOOL ARC2223 FRIDGE/FREEZER
I cut it out of the system in the end, the machine is in the kitchen so the heater should never be needed, thanks for your help.[/list]
JOHN CLARKE
Thanks johnmac11, at least I know what it does, now I wonder why it blew the house fuse when I connected it to the thermostat.
JOHN CLARKE
ParticipantRe: Beko WM7147W Motor
Thankyou Spindoctor.
JOHN CLARKE
ParticipantRe: WHIRLPOOL AWM5104/05.
Thanks bazza500, these are the items that I have recieved from Connect, they don’t fit together. I’m beginning to think that perhaps one or the other part is wrongly packaged.
JOHN CLARKE
ParticipantRe: Zanuzzi Freezer ZUF105W (frost free)
Thankyou for your replies, I’ll go for the thermistor (NTC), thanks again.
JOHN CLARKE
ParticipantRe: Hotpoint WD71
Will she notice the different spin speed,not many do.
JOHN CLARKE
ParticipantBOSCH WFT2806GB/13 NOT HEATING.
I think you are right Martin, I’m blaming the Heater Relay, have you seen the price of those modules, I don’t think she will have that job done.
