ben–nevis
ParticipantRe: De- Dietrich, Induction Hob. DTI704V
In order to determine if it is the power card or keyboard card, you will need to swap over the left and right power cards to see if the fault transfers to the other side of the hob. you do not need to remove the coils from the power cards to do this only the mains connection the bus wire connection for the keyboard card and the earth screw. The code is a config code that is factory set and is not a fault code this clears after 30 seconds or so, or if the controls are used.
Hope this helps
ben–nevis
ParticipantRe: Fagor F07
Hi Jon,
IF you send me your email address I will send over the full training package on the machine.
Bill
ben–nevis
ParticipantRe: de dietrich DME555 EX1 tripping rcd
if you let me have an email address I can send you a training package for the oven.
hope this helps
ben–nevis
ParticipantRe: de dietrich dti318je11
The hob is in child lock. IF you look at the right hand controls for the appliance there is a paddlelock shown below the + and – symbols ( either on timer or power controls ) press both together for 3 seconds to remove. This can be put on when the customer cleans the hob with a wet / damp cloth.
Hope this helps
ben–nevis
ParticipantRe: DeDietrich oven MP3160N1
It may be worth checking the door lock. The switch on the assy. is designed to cut off the element and fan if the door is opened during use. This is more comon on 2003-7 machines.
I hope this helps
ben–nevis
ParticipantRe: De Dietrich DOD338XU11
Sorry as this is a double oven the strike is below the top oven door not the control panel.
ben–nevis
Sounds like the door lock to me. If you have no fan or fan element and the oven light is on all the time. On the right hand side, betweenthe door and control panel, you should have a plastic switch strike which lines up with a recess on the top of the door, this plastic can break.
Hope this helps
ben–nevis
ParticipantRe: Hot fill dishwasher
As with a lot of Manufacturers De Dietrich and Fagor machines can connect to hot water up to 60 degrees.
It is worth bearing in mind that if ANY brand machine uses a cold inlet to aid the condenser drying this will be affected by using hot water, also any cold rinses will also use hot water, so unless the customer has solar / heat pump, it is not always the best option
ben–nevis
ParticipantRe: Dedietrich dvh610 03 heating fault
Hi John,
As mentioned above there is a door switch that controls the model on this model, so worth checking. If you require a service manual on this model PM me your email address I will send one over.
ben–nevis
ParticipantRe: whitegoods analysis
Hi Dave,
It may be worth contacting AMDEA for any info.
Address: AMDEA
Rapier House
40 – 46 Lambs Conduit Street
LONDON
WC1N 3NW
UKTelephone: +44 (0)20 7405 0666
Facsimile: +44 (0)20 7405 6609
E-mail: info@amdea.org.uk
Hope this helps.
ben–nevis
ParticipantRe: Fagor 2FU-3611IT integrated washer – F2
Hi Steve,
If you PM your email address I will send you any tech info I have on the machine.
regards
ben–nevis
ParticipantRe: Customer quoting Sale of Goods.
Hi Jag-12
http://www.secola.org/db/2_12/gb_noteslong.pdf
Well worth a read and gives examples to quote
Hope this helps
ben–nevis
ParticipantRe: De Dietrich halogen bulbs
HI Dave,
We have tried normal G9 lamps and have no problem with them at all.
Bill
ben–nevis
ParticipantRe: DeDietrich Dishwashers???
While De Dietrich are now owned by Fagor, all De Dietrich 60cm dishwashers are made in France and Fagor 60cm made in Spain. 45cm models I would need the model number to confirm the origin.
The washer Drier mentioned would be at least 6 years old on the electrolux / AEG platform mow all made in Spain.
Should you require any tech info please let me know, I will be happy to send any I have.
Bill
ben–nevis
ParticipantRe: de dietrich 428 xu1 no heat from oven
As Martin has said the first place to start is the element If the appliance is Pyroclean I would suggest the door lock as this prevents the fan and fan element from operating with the door open. conventional will work ok. Please let me have an email address and I will be happy to send wiring info should you need it.
Bill
