bobokines
Viewing 15 posts - 151 through 165 (of 760 total)
  • in reply to: Diplomat APM8703-2 Internal dispenser hoses #222929
    bobokines
    Re: Diplomat APM8703-2 Internal dispenser hoses
    Apparently there are ten of these machines in the same block and three have flooded. They are all only a few months old.
    If there is a kit I think I might need it!
    Bob
    in reply to: Diplomat APM8703-2 Internal dispenser hoses #222927
    bobokines
    Thanks Mike. There’s so much water I can’t see which bit is leaking.
    When I turned the machine on I got hit straight in the face 😯
    Thanks again
    Bob
    in reply to: not spinning #222820
    bobokines
    Re: not spinning
    There used to be a test procudure printed in the Hotpoint service manuals on the old 95 series machines.
    It involved shorting out the triac and using an analogue meter across the live and neutral on the plug top.
    The meter would fluctuate when the motor was turned as long as the arm and field wiring was in tact. It didn’t test the tacho and obviously won’t work on the later machines with a thermal door lock.
    Bob
    in reply to: should a grill element glow? #222702
    bobokines
    Re: should a grill element glow?
    Thanks Ken
    in reply to: wf 860 cancel test mode #222605
    bobokines
    Re: wf 860 cancel test mode
    I’m convinced that these machines are going into test mode due to radio interference.
    I have one of these machines in a remote area that suffers from voltage drops and spikes.
    The machine had gone into test mode every few weeks over the past year or so.TThe customer is old and unable to sort it themselves. They were ok paying me to pop in and reset it but it got a bit stupid.
    Last time I called I suggested that the customer buys a surge protector mains socket (like you use to protect the PC from voltage surges) This was over six months ago and I haven’t been back!
    Bob
    in reply to: Belling G923AN Knobs #222329
    bobokines
    Re: Belling G923AN Knobs
    Thanks mate. That’s them 😀
    Bob
    in reply to: AEG sensortronic 1051 door seal #221481
    bobokines
    Re: AEG sensortronic 1051 door seal
    :tup:
    :rolls:
    in reply to: Neff integrated tumble dryer no go #221353
    bobokines
    Re: Neff integrated tumble dryer no go
    Went there today to continue the search for the fault, armed with all the guff you guys have sent me. The bloody thing worked first time at turn on!
    For information, there is a child lock… it entails holding the select button for 6 seconds. 6 seconds again to unlock.
    Thanks again for all the help
    Bob
    in reply to: AEG sensortronic 1051 door seal #221479
    bobokines
    thanks Chris, Why couldn’t I find that?
    in reply to: hotpoint wd61 #221314
    bobokines
    Re: hotpoint wd61
    A high percentage of the cold water normally flows through the condensor and only a small bit flows through the soap dispenser. The usual problem here is a blocked flushing hose to the condenser. This is the hose that ‘doubles back’ from the dispenser.
    Bob
    in reply to: Neff integrated tumble dryer no go #221351
    bobokines
    You’ve got me thinking now about a child lock. Anybody any ideas on how it is activated/deactivated?
    Bob
    in reply to: Neff integrated tumble dryer no go #221349
    bobokines
    Thanks Boys.
    ….Child lock, now there’s a thought :rolls:
    Bob
    in reply to: Neff integrated tumble dryer no go #221346
    bobokines
    Greg. I thougth that too, however, it is possible (with a bit of contortion) to close the main door with the flap open. This would leave the rotating fan open to little fingers. Hence the reason why I was convinced that there must be a switch somewhere. The two brown wires are confusing me a tad too.
    Do you know if there is a diaganostic for this machine?
    Bob
    in reply to: Neff integrated tumble dryer no go #221344
    bobokines
    Martin wrote:
    bobokines wrote:
    ( can’t find this machine on the Bosch website)
    It’s a R4381X1GB/01 Bob, and there is a switch that the bottom access flap operates I believe on that beast. 😉
    That would account for why I can’t find it on the bosch site 😳
    However, still can’t find the bloody switch 😥
    Bob
    in reply to: hotpoint wd63p-no heat #220042
    bobokines
    Re: hotpoint wd63p-no heat
    Another possible, make sure that the speed control resistor (if it has one) hasn’t been put on the variable temp position by mistake.
    (it’s the back two connectors marked 52 to 57 on the sheet that I sent you)
    Bob
