bobokines
Viewing 15 posts - 136 through 150 (of 760 total)
  • in reply to: Siemens dishwasher SE24207gb/01 door leak #224890
    bobokines
    Re: Siemens dishwasher SE24207gb/01 door leak
    Have you taken the door outer panel off and checked it’s not leaking from the dispenser area and running down inside the door?
    If you run it with the door panel off you will see if it is leaking from the lower door seal
    Bob
    in reply to: Hotpoint TDC60S Heats for few mins #224895
    bobokines
    Re: Hotpoint TDC60S Heats for few mins
    Have you checked the earthing strap on the rear bearing shaft?
    Bob
    in reply to: LG WM1480FHD Washing Machine #224854
    bobokines
    Re: LG WM1480FHD Washing Machine
    Easy. Very similar to a bosch to take the front off. There is a wire band clip holding the door seal to the drum. The drum unit is very similar to the old Hotpoint 95 series.
    Bob
    in reply to: How difficult are Miele Repairs? #224804
    bobokines
    Re: How difficult are Miele Repairs?
    Thanks Seamy, I noticed the wiring diagram.
    What sort of guarantee do they carry?
    Although the parts are pricey, I think most customers will accept that you have to pay for quality. My labour charge is only a fraction of Miele’s call out!
    I Think I will add Miele to my list from today.
    Bob
    in reply to: Whirlpool Dishwasher NTC #224796
    bobokines
    Re: Whirlpool Dishwasher NTC
    I’d love to find a cheaper version of this part. Can you try a resistance comparison check at a few different temperatures?
    Bob
    in reply to: Baumatic Hob B12SS – Switch #224759
    bobokines
    Re: Baumatic Hob B12SS – Switch
    Connect show this as BMTXREG30001
    Bob
    bobokines
    Re: Neff r4381x1gb/01 condensor tumble,, urgent help please
    I guess you’re happy then 😉
    Bob
    bobokines
    I had similar problems a few weeks ago…
    http://www.ukwhitegoods.co.uk/modules.p … t=neff+bob
    In my case the damn thing came back to life on it’s own. However I did discover that the child lock is activated and deactivated by depressing the select button for 6 seconds.
    Bob
    in reply to: Neff butterfly oven elements #223890
    bobokines
    Re: Neff butterfly oven elements
    I’m with Jim. I give twelve month gtee.
    The customer has paid for the repair. Cut your losses, supply another element FOC for good will.
    You have little to lose and much to gain.
    Bob
    in reply to: Whirlpool AWM 045 #221252
    bobokines
    Re: Whirlpool AWM 045
    Reading through the thread again, it appears as if you stopped looking for the fault when you found the blown track and assumed that the blown track was the reason for no-go. Is it possible that the machine has been working with the blown track for a while and the customer was unaware that the valve was not working? Perhaps it was the hot valve or the Fab valve?
    Your original post looked like a typical no motor action. The first thing a whirlpool does after energising the door is to test the motor. If the motor is O/C or there is no tacho feedback then it will just sit there!
    I would test motor continuity from the timer connector plugs.
    Bob
    in reply to: Fault Code Guide #223194
    bobokines
    Re: Fault Code Guide
    Ken, can you reserve one for me too please.
    Bob
    in reply to: creda dryer stops #223172
    bobokines
    Re: creda dryer stops
    Ditto…
    Check the mains supply.
    I have been caught out by faulty moulded plug top!
    Bob
    in reply to: w/pool adg957 dishwasher #223001
    bobokines
    Re: w/pool adg957 dishwasher
    Make sure that the top basket is going all the way home. Could be a broken basket wheel. This has thrown me before.
    Bob
    in reply to: Diplomat APM8703-2 Internal dispenser hoses #222935
    bobokines
    Re: Diplomat APM8703-2 Internal dispenser hoses
    Thanks boys. That’s the information that I needed.
    Bob
    in reply to: Diplomat APM8703-2 Internal dispenser hoses #222931
    bobokines
    ken, here’s your wake up call
    Bob
