bobokines
Viewing 15 posts - 241 through 255 (of 760 total)
  • in reply to: Bluetooth or Handsfree? #205747
    bobokines
    Re: Bluetooth or Handsfree?
    Martin,
    have you had any conflict between your radio and your headset. I mean, if you leave the car, does your headset work automatically or do you have to re-configure it and conversely, when you get back to the car, does the bleutooth radio take over?
    Bob
    in reply to: TDS 2007 install problems #205598
    bobokines
    Re: TDS 2007 install problems
    I ordered DSTDVD2007 now showing as in stock at Connect..
    Bob
    in reply to: TDS 2007 install problems #205596
    bobokines
    It was a clean install on a new computer. Eventually it installed after about ten attempts.
    I got it from Connect. It was showing nil stock but arrived on the next delivery. Lucky me!
    Bob
    in reply to: Privelig dryer 3005cd (german market) #205654
    bobokines
    Re: Privelig dryer 3005cd (german market)
    it’s the stat on the left. A model number for a UK machine with the same stat layout would probably be all I need.
    Bob
    in reply to: creda 37753e dryer sensor #205664
    bobokines
    Re: creda 37753e dryer sensor
    Don’t forget to check the earth strap on the rear bearing shaft. If it’s broken or been lubricated with a non conductive grease then the sensor won’t work.
    Bob
    in reply to: It has been suggested… #204167
    bobokines
    Re: It has been suggested…
    Great. I’ll be there.
    Anyone coming from the south east? I’ve got room for a passenger.
    Bob
    Edit… Sorry, I won’t be going straight back on the Saturday now so its probably no use for a lift for anyone.
    in reply to: Aeg dishwasher poor wash results #205422
    bobokines
    Re: Aeg dishwasher poor wash results
    Thanks boys. I think I will go and have another look before ordering a motor.
    My TDS disk died so I could not look up the info in the house. Now I have the new disk I will go and check for error codes etc.
    The water level seemed to be ok. I did not check to see if it started to heat as there was obviously a water pressure problem.
    The capacitor is a possible…
    Bob
    in reply to: It has been suggested… #204165
    bobokines
    Just booked a room. 😀 It will be good to meet everybody again.
    Are you planning anything earlier in the day or do we just arrive for the evening?
    Bob
    in reply to: hotpoint dryer tdc62n #202726
    bobokines
    Re: hotpoint dryer tdc62n
    sorry for repeated replies. Somethig wrong with the system here.
    Bob
    in reply to: hotpoint dryer tdc62n #202725
    bobokines
    I take it that you meggared the machine. A DTE element can cause this fault.
    Bob
    in reply to: Beko DE2541FX #205340
    bobokines
    Re: Beko DE2541FX
    Check the seal to the top spray nozzle at the back of the machine. I have had two Beko’s with a split nut on the nozzle. Both had been sealed with mastic at the factory and had lasted about two years before failing.
    Bob
    in reply to: whirlpool awd3961 #205489
    bobokines
    Re: whirlpool awd3961
    Pretty sure it will be worn brushes.
    Bob
    in reply to: LG door gasket #205470
    bobokines
    Re: LG door gasket
    It’s a bit like a Bosch if I remember correctly.
    Might need a helping hand to hold the top of the spring in place whilst pulling the rest of the spring in place.
    Your customer might be trying to fit it without removing the front panel. 😕
    Bob
    in reply to: Aeg dishwasher poor wash results #205419
    bobokines
    baron wrote:It happen at Zanussi (Aeg) dishwasher that pumps impellor to lose pallets (damaged wings, little), so lose power…
    8)
    That was my first thoughts but this is the [proper] AEG machine with the motor at the back right hand side. The impellor and pump housing is fine. I’m a bit stumped as the motor appears to be free and sounded as if it was going at the right speed. It pulses at two speeds so I am assuming that the electronics are ok. Running with the door open, at low speed the water barely dribbles out of the lower spray arm and when it pulses at high speed it has better flow but no-where near the correct rate.
    Unfortunatly it is a built-in machine in a small kitchen and I have no way of water testing it with the side panel off.
    Bob
    in reply to: Aeg dishwasher poor wash results #205417
    bobokines
    Thanks, I have had the new disk delivered today. See if it works
    Bob
