bobokines
ParticipantRe: Thirsty Hotpoint WM64
It’s the black edge connector on the timer.
Bob
bobokines
ParticipantRe: indesit w101 fault
Look for an earth fault on the pump wiring. It might not show from the plug top when empty.
Bob
bobokines
ParticipantRe: Foreign Objects/Zanussi Drum
Take off the sump hose and try to feel the foriegn object. Pass a length of string down through the front plate and out though the sump hose. Fray the end of the string and attach a small piece of blue-tak or something similar to the end of the string. Then try and stick the blue-tak to the foriegn object and pull it out through the front of the machine. I have done this three times successfully.
The other technique that I have tried… with limited success… was to use a vacuum cleaner with the nozzle pushed into my trusty syringe and a length of pressure hose to suck up the foriegn object.
Bob
bobokines
ParticipantRe: Hotpoint dishwasher Mod 7821
walnut wrote:
Customer reported dishwasher was sticking and making a funny sound.It’s not unusual for the timer motor gear to come loose from the timer motor shaft. The gear wheel should be flush with the end of the timer motor shaft. The recognised fix was to use loctite but I used to roughen up the shaft with side cutters and push the gear wheel back on.
Bob
bobokines
ParticipantRe: Brews!
Years ago, I poured mine into the washing machine… Like you do… Only to find the customers net curtains inside… Whoops. 😳
Bob
bobokines
ParticipantRe: Hotpoint WMA63
In the backof my mind I remember an incident on this machine where the hoses were reversed (hot and cold) and the machine sticks on the stepped cooling rinse cycle.
Bob
bobokines
ParticipantRe: Bosch DW SGS43A32GB/01 – o`filling
Be careful to put the magnet back in the right way up! Float it in a glass of water to see which way it is happy.
I have one of these in a carvery restaurant where they use a sharpening steel a lot and have lots of iron filings.Nice easy job. I tell them that they can do it themselves but they seem to be happy for me to do it every six months or so and pay my labour charge. 😉
Bobbobokines
ParticipantRe: How difficult can it be to……
Conversely… I have no problems at all with Thomson. They are my best advert. Yellow Pages on the other hand have been awful!
Yesterday, the Yellow Pages rep came to see me to sell me next year’s ad. He was very upset when I told him that I am only going to have a token advert next year as this year’s (and the last two year’s) advert has not worked for me.
He quoted me loads of statistics to say how much better Yellow Pages are compared to Thomson! He went away with a flea in his ear.
Bob
bobokines
ParticipantRe: Re necht dishwasher?
When I said I have worked on these, perhaps I meant I have seen a few. I have had the odd blocked pump and one with a heater faulty and was able to replace it with an indesit heater. The machines seem very similar in design to the merloni ones that we all love to hate.
The baskets are crap on these…
Bob
December 15, 2005 at 6:36 pm in reply to: Cant find number for pressure switch old type 2 level #157437bobokines
ParticipantRe: Cant find number for pressure switch old type 2 level
Searching for SER40011700 on connect DVD converts to SER520002100
If you click on alternative on the properties box it shows the alternatve to be a two level switch 5031684817696 😕
Bob
bobokines
ParticipantRe: creda620 not heating
Before you take the machne to pieces, check that there is not a blockage in the valve at the back of the water bottle. The valve is in two pieces, one attached to the bottle itself with small plastic clips and the other part is at the back of the machine held by two screws. You will need a long magnetic tip pozi screwdriver. Watch for sharp edges! I’ve got scars to prove you can’t do it with a short screwdriver.
Bob
bobokines
It’s interesting to read about the tie up with merloni and Swan.
http://www.littleswan.com/en/news/newsdesc.asp?id=198
I have worked on a few of these and, to be honest, they seem to be a better build quality than the ‘normal’ Indesit crap. Or is it my imagination?
Bob
bobokines
ParticipantRe: diy’ers
To open this debate further… the information posted on the open forums can be… and will be… read by other users without our control. There has to be a level of common sense here.
Bob
bobokines
Jeremy.
I’m sure no-one here has an issue about you expressing an opinion. That’s what this site is all about!
Its a very difficult line to draw when deciding how much technical information should be given out over the phone (or over a web chat forum). Personally I would prefer to advise a customer over the phone that her machine has a user accessible filter than to get the house and simply clear the filter and charge for a callout.
Bob
bobokines
I think the point here… within the public forums in UKW… is to ensure that the DIYer’s will only practice their DIY ‘safely’ and to promote the services of us independant engineers.
The advice given here is unlikely to lose us work as, let’s face it, they will have a go anyway with or without our help. This way they are not going to delve too deeply into unknown teritory.
Good point though… How do you other lads feel?
Bob
