bobokines
Viewing 15 posts - 541 through 555 (of 760 total)
  • in reply to: Cant find number for pressure switch old type 2 level #157433
    bobokines
    Re: Cant find number for pressure switch old type 2 level
    You will find the part number printed on the pressure switch itself.
    Bob
    in reply to: Tricity Bendix Strata Cooker #157259
    bobokines
    Re: Tricity Bendix Strata Cooker
    If you search the connect site for Strata as the model number there are not that many ceramic hob versions.
    Try CSIE452B
    good luck
    Bob
    in reply to: Smeg SE398X/1 stat #157345
    bobokines
    Re: Smeg SE398X/1 stat
    Thanks Chris. I owe you a pint…
    Bob
    in reply to: Zanussi FLA 1201W motor price #157238
    bobokines
    Re: Zanussi FLA 1201W motor price
    My Connect prices went down by nearly 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} after I spoke to my rep. It’s well worth contacting the sales team and arranging a visit.
    Bob
    in reply to: whirlpool dryer AWZ241 #157301
    bobokines
    Re: whirlpool dryer AWZ241
    My God! I said it would be about £30! It’s only the start button broken off. I wonder if it will glue?
    I will phone Whirpool on Monday to see what they can do.
    Bob
    in reply to: Bendix bwd1012 #156079
    bobokines
    Re: Bendix bwd1012
    Just to put this one to bed… It was the control unit.
    Thanks lads
    Bob
    in reply to: Zanussi FLA 1201W motor price #157232
    bobokines
    Chris, you really do need to buy your connect rep a pint or two. My connect price for this motor is £90.97!!!
    in reply to: Diplomat ADP3200 #157204
    bobokines
    Re: Diplomat ADP3200
    Thanks so much Dave.
    Where would we be without you!
    Bob
    in reply to: Creda C366ewh #157163
    bobokines
    Re: Creda C366ewh
    Thanks Dave. I’m having a nighmare week.
    Jesus said… “Smile, things could be worse”, So I smiled and things did get worse!
    Bob
    in reply to: servis m3814 x16 #157154
    bobokines
    Re: servis m3814 x16
    Could be the heater has warped due to going through heat pause with little or no water. It might be striking drum in mid spin.
    Have you meggared the heater?
    Otherwise I would go for a motor fault.
    Bob
    in reply to: Creda 37747 Condenser dryer #153350
    bobokines
    Re: Creda 37747 Condenser dryer
    No sugar please…
    in reply to: Creda 37747 Condenser dryer #153348
    bobokines
    I agree with Jim that the stat above the door normally fails open circuit and there is usually signs of overheating on the terminals. However I have known one fail closed circuit and that will cause the overtemp stat to cut out. Test in against a hot cup of tea. It should open at 78 degrees C and close at 58C
    Bob
    in reply to: indesit wdg1295wg (no high spin) #157126
    bobokines
    Re: indesit wdg1295wg (no high spin)
    I’ve had several indesit/aristons with old type timers that have this symptom. It is the timer at fault although the sympton appears as if it the module or motor
    Bob
    in reply to: smeg DWF410SS #156932
    bobokines
    Re: smeg DWF410SS
    Thanks Dave, you’re a star
    Bob
    in reply to: Best Van to buy? #156549
    bobokines
    Re: Best Van to buy?
    I’ve just bought a Doblo too. It has the new 1.3l multijet engine but is not as ecomonical as they would lead you to believe. I struggle to get 37MPG from it.
    I went for the basic version as the price was right and it fits the bill for me but I would have preferred side loading doors. Beggars can’t be choosers.. It was a very good price. Last year’s plate but only 4 miles on the clock and only £4995.
    It has an annoying design fault… The interior light will not come on when the front doors are opened if the ignition has been off for more that 20 minutes! Apparently it is because it does not have cenrtral locking and the body computer hibernates after a short while and won’t wake up until the key is put in the ignition. Not much use on these dark nights.
    Fiat says there is nothing they can do but I intend to rewire the thing as the rear door DOES actuate the interior lights???
    The other problem is the lack of electric windows. I can’t reach the passenger door without taking my seatbelt off.
    That aside it is a great little van. Drives a dream and is very roomy and comfortable. Bloody ugly though!
    You can see my van on my homepage at http://www.seniko.co.uk
    Bob
