jwd_73
Viewing 15 posts - 1 through 15 (of 62 total)
  • in reply to: Fisher Paykel DS605 dish washer #388002
    jwd_73
    Re: Fisher Paykel DS605 dish washer
    HI
    How high is the water when the drawer stops? is it over the rack at the bottom?
    what happens when the drawer stops does it beep 3 times every minute and if it has a display is there a dish symbol flashing?
    or if no display does the blue light flash?
    Reason I ask is could be infa-red issue causing the drawer to pause when hot.
    Newer control modules have an offset prism to stop this issue (the old way was to add a spacer onto the right hand runner to lift the right side up by a few mm)
    John
    in reply to: Fisher paykel dishdrawer #388262
    jwd_73
    Re: Fisher paykel dishdrawer
    Hi Nichog
    99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} chance it is the heater plate part number 528616 (if it is a 603)
    the 1{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} is a faulty control module not operating the heater.
    It is a bit tricky changing the heater plate as the drawer has to come out and be rotated 360* to access it.
    So I would advise getting an expert in who has experience with the product.
    Good luck
    John
    in reply to: Fisher & Paykal Dish Drawer Fault Code #374100
    jwd_73
    Re: Fisher & Paykal Dish Drawer Fault Code
    sounded like a communication fault from board to board or a faulty mains filter board/burn out harness.
    in reply to: Fisher and Paykel E402B – persistent beeping #333395
    jwd_73
    Re: Fisher and Paykel E402B – persistent beeping
    bottom light mostly means one of your fans is not working.
    usually due to a broken wire.
    John
    in reply to: has anyone ever seen one of these ? #333545
    jwd_73
    Re: has anyone ever seen one of these ?
    goosegreen wrote:Creda made them, Replaced loads years ago in the Barbican development in the city of London, Goose
    I thought they looked familiar
    in reply to: famous customers? #330874
    jwd_73
    Re: famous customers?
    Dame Kiri Tekenawa
    Toby Stephens (bond villain, vexed etc)
    Ruby Wax althogh didnt meet her
    Shaun Keaveney (radio dj used to be on xfm now 6music breakfast)
    Victoria Beckhams mum who is lovely and showed me some fan mail that her daughters charity gets it ended with ” I hate you you are a **** , Rebecca loos.” charming.
    A few lords and ladies and tv producers , execs.
    and all very nice people
    in reply to: Teka/Kuppersbusch induction hob Model: GKST 60 i4 #331107
    jwd_73
    Re: Teka/Kuppersbusch induction hob Model: GKST 60 i4
    thanks but all ok now
    got a phonecall from my mum last night ” it was wired up wrong”
    even after I told her sparky twice to sheck the wiring diagram.
    in reply to: Fisher and Pakel DD603 #325801
    jwd_73
    Re: Fisher and Pakel DD603
    pm your email and ill send you some pdfs
    in reply to: Fisher and Pakel DD603 #325799
    jwd_73
    most repairs can be done with machine installed apart from waste hose and inlet hose problems (mice)
    We get a lot of calls to repair mistakes from other engineers that have been called out and most are simple mistakes.
    jwd_73
    Re: Fisher Paykel DD603: upper horrible noise, lower won’t d
    I’ve manged to remove the drawers from the runners and inspect inside but is it actually possible to unplug the variuous cables and completely remove the drawers?
    it is possible but not usually necessary and the first one can be tricky.
    How do I know what mode I am in with a non-LCD model? Where is this documented? Have looked in vain in User Guide and both install PDFs.
    when in diagnostics the red lights above the program symbols light up to the corresponding component.
    Display LED LED LED LED
    bL Off Off Off On Backlight
    Er Off Off On Off Element Relay
    Ld Off Off On On Lid Motors (will run for 10 seconds)
    dd Off On Off Off Detergent Diverter Valve
    FU Off On Off On Fill Water Valve
    P1 Off On On Off Motor Wash direction (2300-2850 rpm)
    P2 Off On On On Motor Drain direction (5000 rpm)
    rd On Off Off Off Rinse Aid Dispenser (dispenses current setting)
    dF On Off Off On Drying fan
    LE On Off On Off Rinse Aid LED
    C1 On Off On On Water Softener Diverter Valve
    C2 On On Off Off Water Softener Brine Pump
    Any suggestions as to what can I try now? A lot of people seem to recommend removing a panel at the back of the bottom drawer and drying interior out with a hairdryer – could this fix a draining problem?
    No but does (sometimes) cure a F1 fault (flood switch activated)
    With regards to the noise it is usually caused by glass damaging the rotor motor and motor housing, sometimes one or both need to be changed.
    The bottom drawer not draining most likely is a blockage in the tube between the filter and rotor motor.
    good luck and if you do find someone nearby make sure they know the machines well.
    John
    in reply to: fisher paykell #312100
    jwd_73
    Re: fisher paykell
    DD601, 2 or 3?
    Still havent come across a dd601 , Stuff of legend 😀
    in reply to: fisher paykel fridge freezer #309803
    jwd_73
    Re: fisher paykel fridge freezer
    Ok if both fans are ok no loose join at the fan end for the top fan or where the wires are pinched for the bottom fan my next guess would be…
    Defrost heater could be open circuit or the heat transfers that clip on the heater and go to the backplate could have fallen off causing a block of ice to build up in the air vent behind the evaporator.
    Good luck[/img]
    in reply to: fisher paykel fridge freezer #309797
    jwd_73
    Test if the fan at back of fridge is working.
    the fan is situated behind the backplate inside the fridge odds are you will find that one of the wires that go into the fan has broken.
    Very very unusual to be a thermistor/sensor prob only ever changed 2
    Good luck
    in reply to: snowed in !!! #307974
    jwd_73
    Re: snowed in !!!
    I did all mine yesterday all over the south in my trusty little van.
    Only lost grip on country ungritted roads a few times.
    in reply to: Fisher paykel DD605H #306241
    jwd_73
    Re: Fisher paykel DD605H
    I would unclip the inlet hose from the softener and aim into large bowl or bucket and run the valve in diagnostics to make sure there is not a blockage in the hose. I have seen it once where the hose was blocked with green particles.
