February 22, 2022 at 2:25 pm in reply to: Hoover DX C10TG-80 not starting with button but works with smart one touch #481334
o_ptic
Participantfound the label Dave, MSW 40011821, USW 40011822 and EEP CODE 40011380. so doesnt look as though its within the range š Doesnt appear that the child lock is on….I suspect this will be a PCB replacement gremlin for sure
February 22, 2022 at 1:49 pm in reply to: Hoover DX C10TG-80 not starting with button but works with smart one touch #481333o_ptic
ParticipantThanks very much Dave, child lock will be my 1st point to check. I dont remember seeing a label on the module but guess that could have fallen off and be floating at the bottom of the machine somewhere?
June 20, 2021 at 8:11 pm in reply to: SMEG SY4110 electric range main fan element not heating #477453o_ptic
ParticipantI think ive found the culprit!
I was given a cheap app based endoscope for my birthday and thought Id put it to good use.
Ive added a link with some photos of the selector switch, you can see that looking from the front of the oven the Right hand side is clean and shiny whereas the left hand side has been burned some of the contact parts are missing.June 20, 2021 at 6:50 pm in reply to: SMEG SY4110 electric range main fan element not heating #477451o_ptic
ParticipantThanks Dave, just double checked again. Looks like I have live on both terminals so have lost a neutral somewhere.
June 20, 2021 at 3:58 pm in reply to: Whirlpool 6th Sense FSCR90410 9kg Washing Machine leaking from detergent drawer #472389o_ptic
ParticipantThanks very much for the reply and I apologies for the lack of response.
I did indeed strip the front from the machine disconnected everything I could, reseated everything and put back together, its been 6 months now and not a single drop has leaked.
I did notice at the time there were 2 of these machines for sale on various sites and both had the same issue, I suspect that Whirlpool are perhaps not assembling the system correctly.
Thank you again though for the advice.October 6, 2020 at 4:29 pm in reply to: Zanussi TDE4234W won’t start 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} the time #471820o_ptic
Participantive repaired my candy ages ago with exactly the same symptoms; my other symptom was that the machine would sometimes end the cycle short leaving the clothes damp. From memory it was the heater relay on the PCB which I replaced it and its still going strong.
o_ptic
ParticipantRe: Bosch WAA28168GB Washing Machine Tripping Electrics
Thanks Martin, for the cost ill order up a set of brushes from the store….by the time I’ve got to them I may as well replace them! How do they fail to short?
October 10, 2011 at 12:21 pm in reply to: Indesit IWME12 Washing Machine – possible overheat/not spin #360964o_ptic
ParticipantRe: Indesit IWME12 Washing Machine – possible overheat/not s
Thanks…yes Ill give it a shot and let you know (no pun intended)
October 10, 2011 at 12:15 pm in reply to: Indesit IWME12 Washing Machine – possible overheat/not spin #360962o_ptic
no Martin, sadly not in the trade but am a handy guy like you say. just trying to do someone a good turn so thought Id ask the question…that is what the forum is for right?
o_ptic
ParticipantRe: whirlpool awz 7913
DDSDDS, the front part that you are referring to is sold as an NTC thermistor from Whirlpoolā¦.although I believe from memory it is actually a simple exhaust thermostat, however the flashing lights on the display are not related to this part.
The machine that I had with the flashing lights had a faulty NTC sensor on the heater (the middle one of the 3) but as you probably know, the sensor is not available as a spare item on its own.
With the dryer that I had when the front stat and heater unit replaced the lights would stop flashing and the machine would run but still no heat was produced.
Im not sure if anyone has any other information but I wouldnāt be surprised if the 6th sense logic board is faulty?o_ptic
ParticipantRe: Hotpoint CTD00T Dryer – excessive vibration
sadly not, I changed the 4 bearing guides/pads located at the front…I guess this must be a later machine?
So to recap on parts replaced;
– front nylon bearing guides/pads
– rear shaft and bearing
– front impeller fan
– rear fan blade
– rear drum sealwhen assembled you can hold the top of the machine and feel the vibrations through the case.
Ive even tried lifting the machine and/or placing on card or an old piece of material….all without change?December 21, 2009 at 11:07 am in reply to: Smeg SUK61CPX5 electric oven – centre fan with no heat #306946o_ptic
ParticipantRe: Smeg SUK61CPX5 electric oven – centre fan with no heat
That sounds like a plan! I’ll check for the internal plate and see if I can whip the element out and confirm with a continuity test…im guessing in some circumstances its probably easy to see the failure without having to check.
Once confirmed Ill follow the link youve provided and order one…lets hope I can repair it ready for the turkey!Thanks again, have a great Christmas.
Steve
December 21, 2009 at 10:35 am in reply to: Smeg SUK61CPX5 electric oven – centre fan with no heat #306943o_ptic
Hi Keith, thanks for the advice…the electrics off and unplugged at the moment while investigating are the elements installed from inside the oven or do you remove the fan unit from the rear and assemble as a unit?
Regards
Steveo_ptic
ParticipantRe: Hoover TV630 – Thermal Fuse Replacement Part
Yes, Iāve used the same fuse before – the rating is a 206C however I’ve always replaced with a 192C part.
As penguin said, find the concern first before replacing againā¦.unless you have a trigger happy Wife who likes to beat the timer and open the door mid cycle?š
March 31, 2009 at 11:50 am in reply to: Whirlpool AWZ7913 exhaust thermostat – is it available? #281649o_ptic
ParticipantRe: Whirlpool AWZ7913 exhaust thermostat – is it available?
I asked my friend who owns the machine when it was purchased, she said that it was early 2007 ā sheās not sure if the guarantee has expired but will certainly check, Iāll tell her to phone Whirlpool for assistance or just bin the machine.
Iāve had a few dryers myself and a fridge freezer that went down quite recently⦠as most people have in a busy family environment; mainly my questions relate to family, friends and neighbours who ask, very few of these items even set foot in my home.
Youāre probably right though, Iāll tell them all in future that they should be not be trying to fix these things but should instead be filling up the recycling centres and replacing with brand new machines, this will give a two fold solution 1) great for the environment and 2) helps us spend loads more cash in the current economic downturn. -
