bobokines
ParticipantRe: old Hotpoint!
My first machine was an 18580 (same machine with but with a chrome door). We bought it in 1980 and my Mum had it from 1987 till last year!
I replaced the original black door seal but other than that it was never worked on
Bob
bobokines
ParticipantRe: GPRS Credit Card terminals
I have signed up through streamikne in conjuction with the Federation of Small Businesses.
I get a 123 Send terminal at an annual fee of £290.82 (inc VAT). I pay this quarterly but it can be paid monthly.
The rates for transactions vary by card issuer but is approx 2{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} for a credit card or £0.305 for a debit card transaction.
I have yet to finds an area where I can’t get a signal. (Even where my mobile refuses to work. )
It does cost me more than normal bank charges for banking cheques but the convenience and professional image makes it worth doing.
I now take this method of payment as my prefered method.
Bob
bobokines
ParticipantRe: Fabric Conditioner Stains
Thanks Martin
bobokines
ParticipantRe: Tricity Bendix DH101 -stopped working
Could be a bad Neutral connection in the supply. Check the plug wiring and try another high current appliance in the socket before investigating inside the dishwasher.
Bob
bobokines
ParticipantRe: wma31
I’ve not seen this on a WMA but it could be a stretched belt giving a false OOB condition. This is common on Servis machines. Certainly no harm done by trying a new belt.
Bob
bobokines
ParticipantRe: 51-BS-08 Bosch Pump
Thought you might like a giggle at the instructions on the box for fitting this thing.
Says it all 😉
:look:bobokines
ParticipantRe: beko dishwasherw D2731FW feed pipe
Sorry found the part listed on Connect site.
Thanks anyway.
I didn’t realise that the Connect website Mediator had exploded diagrams for Beko. And wiring diagrams… very useful 😀
Bob
bobokines
ParticipantRe: Hotpoint VTD00 fire hazard ?
Is there an air leak somewhere or is the vent hose split and the fluff being sucked into the cabinet?
I have seen a few with a worn front felt seal.
Bobbobokines
ParticipantRe: door hinge component Whirlpool cooker
Well done Dave, that’s the bit. 😀
Bobbobokines
ParticipantRe: CREDA T620CW
Check the mains supply first. A fault plug or socket gives the same symptom as a faulty relay.
Bob
bobokines
ParticipantRe: Indesit D63 D/W
JIm, isn’t the thermistor on a DWM55 part of the pcb and clips in under the dispenser?
If so, you need to order the module.
Bobbobokines
ParticipantRe: hotpoint wd61
Tony,
This is quite an interesting topic. I have worked on Hotpoint machines for nearly 20 years and I have never known a timer skip a heat pause for any other reason than a faulty heater, thermistor, economy button or wiring fault.
I am not doubting your integrity… far from it. I just don’t like module/timer changing as the first line of attack.
Unfortunately, in my experience, many [inexperienced] engineers seem to think along the same line as the customers. … “The timer is the bit that I operate so that must be the faulty component”. As you are well aware, this is more often than not the case.
I would imagine that you get quite a few timers returned for a refund for this very reason.
Bob
bobokines
Tony_EMW wrote:Very common this on these 904/2426/02 timer/mods. They skip through too quickly. Change the timer and all should be well. Check thermister though first to make sure around 20-30K when cold. We have the timers in stock. Tony EMW
Tony, surely you don’t condone changing timers as a matter of course before checking every other component?
I’m with Jim here, much more likely to be a heater problem.
Bob
bobokines
ParticipantRe: Hotpoint EW91 inspection cover
Thanks Mike, couldn’t find it listed anywhere.
Bobbobokines
ParticipantRe: Hotpoint – Wma 31n
Bryan wrote:Now who`ll be to blame for that johnny , the Bosch motor or the Merloni electronics :?:……..mmmm I wonder :rolls:.
Bryan
I recon it’s the Bosch motor. I have often had Bosch machines where the brushes wear down below the tamping on the brush (allowing the pigtail to damage the commutator). I can’t honestly remember seeing any other make of motor where the brush does not captivate early enough to stop this kind of damage.
Thumbs down to Bosch in this area.
Bob
