bobokines
ParticipantRe: Belling Format 657hss Knob
Many thanks.
That’s the one
Bob
bobokines
ParticipantRe: Zanussi Washer Dryer Timer advancing
That was my first thoughts with this one.
Strange that there is nothing on the TDS disk about error detection!
Bob
bobokines
ParticipantRe: Bernstein d/w
If you found the wiring diagram then you know where the timer is.
Give the timer a click or two clockwise to see if it kicks into life; if it does then suspect the start button or wiring. All the start button does is to supply power to the timer motor.
Have you checked the door switch btw ?
Bob
bobokines
This totally threw me.
When the circulation motor starts it puts a negative pressure on the second pressure switch system that confuses the processor and sends it into a safety protection mode. ie advance to end…
Bob
bobokines
Thanks WVM
You were spot on. :tup: Small plastic bag stuck in behind filter.
Thanks again.
Bob
bobokines
ParticipantRe: Beko WMB10 Heater bracket
It only takes ten minutes to take the inner drum out.
I think you would struggle to fit it without removing the drum.
Bob
bobokines
I’ve had two of these myself.
I now carry a heater bracket as van stock.
BEK2801660101Nice easy job.
Bob
bobokines
ParticipantRe: recalls
funkyboogy wrote:1 recall in 10 years….
that takes a bit of beating….
?Takes a bit of believing…
Bob
bobokines
ParticipantRe: A Warning
neptune wrote: At the risk of appearing ignorant, what is a voltage stick?
Bob
bobokines
ParticipantRe: Zanussi FL812
If it’s an induction motor it MUST have a capacitor
Bob
bobokines
ParticipantRe: Urgent. Hotpoint WMA46S door will not lock
Could be a broken latch spring. I have seen this several times.
Bob
bobokines
ParticipantRe: hotpoint engineers cannot solder
Johnny, I will let Cab respond to this himself but I think there was just a hint of a joke in there somewhere!
Please don’t take it out of context.
Bob
bobokines
ParticipantRe: Whirlpool module terminology
Thanks mate 😉
bobokines
ParticipantRe: hotpoint wf250 prewash light flashing
Prewash light flashing on a Hotpoint machine is normally a fill time out.
Bob
bobokines
When I worked for Hotpoint I was taken aside and given a good talking to for carrying a soldering iron.
We had a serious problem with Microtronic Dishwashers, some 5 years ago, failing due to a bad solder connection on the thermistor connection on the power board. When the boards become unavailable they would do a concessional exchange rather than let us solder the boards.
Bob -
