dave-m
Viewing 15 posts - 1 through 15 (of 199 total)
  • in reply to: Bosch WVD24520GB/07 #374679
    dave-m
    Re: Bosch WVD24520GB/07
    I’ll try the water boarding and the element, one of them has gotta work…….
    in reply to: Bosch WVD24520GB/07 #374676
    dave-m
    I assume there was no conclusion to this snag?
    Is there a way of interrogating hidden fault codes?
    in reply to: Bosch WVD24520GB/07 #374674
    dave-m
    Cheers for that, I’ll give it a go before I give up.
    in reply to: SIMPLE PCB REPAIR TIPS #309725
    dave-m
    Re: SIMPLE PCB REPAIR TIPS
    See attached a PDF version of this thread to add to your phone/teblet etc.
    Regards
    in reply to: Bosch WVD24520GB/07 #374672
    dave-m
    Anyone?
    in reply to: Bosch WVD24520GB/07 #374671
    dave-m
    Hey guys,
    I’m reviving this thread as I’ve one with the same problem.
    Same E-Nr and it stops at 12 mins left and stays like that.
    Motor, pump, heaters, solenoids good. Meggered m/c and all good. Can’t find any wiring issues.
    Had the same problem a couple of years ago and came to the conclusion that it must be the board. Can’t remember the price but the customer would not go for it so never proved it.
    Would like to try and prove this one, is there a way of accessing stored errors?
    Has anyone solved this problem?
    Regards
    in reply to: Siemens WDI1440GB/04 FD 8606 #420441
    dave-m
    Re: Siemens WDI1440GB/04 FD 8606
    I’ve not gone to it at all yet.
    Was at it a while back for a reset of the heater stat on the dryer, it’s worked ok since today and they sent me a pic showing what I’ve described above.
    They said they tried holding the start button (and all the others individually) to try and get it to go.
    I said I’d call tomorrow.
    in reply to: Siemens WDI1440GB/04 FD 8606 #420439
    dave-m
    Tried holding the start button, but maybe not for 10 seconds.
    Do you know what it means?
    in reply to: Miele KM540 Hob #416670
    dave-m
    Re: Miele KM540 Hob
    Thanks Martin
    in reply to: Beko dcu8230 Condensor dryer No heat #401344
    dave-m
    Re: Beko dcu8230 Condensor dryer No heat
    No problem, thanks for the quick reply.
    I might try and change a relay and see how i go.
    I’ll let you know the outcome
    Regards
    in reply to: Beko dcu8230 Condensor dryer No heat #401342
    dave-m
    Any fix on this, I’ve the same problem.
    Is there a relay on the board i could change?
    in reply to: Miele W828 #411066
    dave-m
    Re: Miele W828
    Cheers Martin.
    Just found the manual myself this second and sure enough, you can open the door.
    It says you can open during any stage of certain washes except if temp is over 55 or if it’s spinning.
    Everyday is a schoolday.
    in reply to: Lux EDC75770w 91609616801 #403348
    dave-m
    Re: Lux EDC75770w 91609616801
    If I could get the info for the 00 that would be great.
    Dave@dmappliances.com
    Thanks a mil.
    in reply to: ZDC67550 manual #402902
    dave-m
    Re: ZDC67550 manual
    Thanks a mil Colin.
    in reply to: ZDC67550 manual #402900
    dave-m
    Re: ZDC67550 manual
    916 096 169 12
