bobokines
Viewing 15 posts - 196 through 210 (of 760 total)
  • in reply to: Hotpoint 6550B top oven door hinges #213451
    bobokines
    Re: Hotpoint 6550B top oven door hinges
    Hi Chris
    That’s the hinges for the glass lid. I need the drop down hinges for the top oven door.
    It’s my own appliance! My wife thinks my service is dreadful! She’s waited two weeks already! 😆
    Bob
    in reply to: Aeg lavamat W/D L16810 pnc 914601605/02 #211876
    bobokines
    Re: Aeg lavamat W/D L16810 pnc 914601605/02
    I believe that E90 is a communicatoin error. Usually a bad connection between the two boards.
    Bob
    in reply to: Stoves Newhome cooker glass #210699
    bobokines
    Re: Stoves Newhome cooker glass
    My problem is that I have come up with 081551863 and 081551832 both with the description as top oven inner door for this model. 😕
    One site shows 081551864 as a main oven door! :rolls:
    Bob
    in reply to: Hotpoint d/w #210389
    bobokines
    Re: Hotpoint d/w
    If the water is heating then it is either cycling on the 85C stat(s) caused by localised heating (often caused by restricted lower spray arm). or the timer motor is not being turned back on by the control stat(s). You need to establish how hot the water is getting during the heat pauses.
    There are two N/O stats in the door, one is 50C the other 65C. These stats supply power to the timer motor when the water reaches the correct temperature.
    Other things to check:
    Ensure that the water level control is not blocked. Reduced water level will cause the heater to cycle on the 85C stats.
    Check that the timer motor is running and that the timer motor gear has not come off the end of the shaft.
    Bob
    in reply to: Fault Codes on AEG Lavamat 74335 #164142
    bobokines
    Re: Fault Codes on AEG Lavamat 74335
    MIke. I had the self same thing a week or so ago. Mine was the analogue pressure switch too.
    Just a note for anyone following this topic though. A blocked recycling pump can give this error code on some machines. As soon as the recycling pump cuts in, it puts a negative pressure on one of the pressure hoses and gives a conflicting message to the module.
    Bob
    in reply to: Beko dv5531g electric cooker #209807
    bobokines
    Re: Beko dv5531g electric cooker
    The wiring diagram is on Connect Mediator.
    Sorry,I don’t know how to copy it to mail it to you.
    Bob
    in reply to: Candy Condenser Dryer CDC266UK Float Switch #208783
    bobokines
    Re: Candy Condenser Dryer CDC266UK Float Switch
    Thanks Chris. Isn’t it a sod of a machine to work on!
    Thanks again
    Bob
    in reply to: Zanussi DWS939 D/Wash – Pump Impeller #207705
    bobokines
    Re: Zanussi DWS939 D/Wash – Pump Impeller
    I have used a pattern part from Connect (PMP9004) before now. It’s only about £30.00 trade.
    Bob
    in reply to: AAAAAaaaaarrrrgggghhh!!!!!!!Zanussi door seal. #140081
    bobokines
    Re: AAAAAaaaaarrrrgggghhh!!!!!!!Zanussi door seal.
    roly16 wrote: It only takes a few seconds.
    Took my customer two days! then he gave up!
    You’re right, when you have done a few it only takes a few seconds with the clamp.
    There are several useful tips in this thread. It’s worth another read through.
    Bob
    in reply to: 6204370 element Price? #208302
    bobokines
    Re: 6204370 element Price?
    No… I think the moral of this story is to be vigilant and cross check prices.
    I often cross check prices between suppliers but now I check which prefix to use as well.
    Bob
    in reply to: Electra 17052 #208314
    bobokines
    Re: Electra 17052
    mitchep wrote: this process continues indefinitely.
    Jim. This is classic syphoning syndrome.
    It’s likely that the drain hose discharges into a sink or standpipe that is too low. The end of the drain hose must be above the level of water in the machine otherwise the water will syphon. It will only happen on the synthetic cycle at this one spot due to the step cooling.
    There is a red line printed on the back of the machine as an indication of the minimum drain pipe height.
    Bob
    in reply to: 6204370 element Price? #208300
    bobokines
    iadom wrote:Try looking at a 91944064 Candy/Hoover door hinge, comes up as over £20.00 from Qualtex/Spareslink and £3.00 at Masterpart. 😕
    That part keyed as HVR91944064 on Connect is £26.07. Key the same part number without the HVR prefix and it superceded to CAN49001262 (£4.48 or 5+£1.89) 😕
    Bob
    in reply to: AEG 42300 FACIA #208295
    bobokines
    Re: AEG 42300 FACIA
    Thanks Chris
    You’re a little gem
    Bob
    in reply to: askoll #207518
    bobokines
    Re: askoll
    Oh! I make sure the customer pays for the part 😉
    There are other sources for this size clip and it has been voiced here before. But they do for me.
    Bob
    in reply to: Hotpoint BF162 DW aborting program #207735
    bobokines
    Re: Hotpoint BF162 DW aborting program
    Yep.. I stand corrected.
    It always amazes me when these heaters fail. It always throws me.
    Bob
