Micky 32
ParticipantI have came across this issue twice. I threw water into the drum and set it to spin. After a few minutes the machine went into a spin. I let it finish and they both worked afterwards. I could have been lucky though.
Micky 32
ParticipantI was meant to update this. Sorted. I replaced the cooling fan and it worked ok.
Micky 32
ParticipantI came across one 6 months ago. I reflowed the relay solder joints. 6 months on still works ok.
Micky 32
ParticipantI came across 2 machines that wouldn’t start a wash after they were both blocked and cleared. I threw some water into the drum and set it to a spin. It will eventually go into a spin. Let it finish. In both my cases it reset the machine and worked ok. Maybe i was lucky.
Micky 32
ParticipantThanks for the replies. I bought the pld1822 and used it on a Blomberg today. Worked a treat. It should be called the anti cursing clamp lol
Micky 32
Participantelectrofix wrote: found this hope it helps
Thank you Dave, appreciated
Micky 32
ParticipantHollytree_Technical wrote:If the fuse is gone then the timer wouldn’t be ticking away as it is also in line to the timer.
My suggestions would be to check
- That the belt hasn’t snapped or come off of the tensioner (there is a switch that detects the tensioner being loose).
- Check the thermal fuse on the exhaust duct (two blue wires) as this is inline with the motor on these.
- Do you hear any buzz from the motor when you press the start switch? if so then you may have a bad motor or centrifugal switch.
There is usually a wiring diagram on the inside of the lower cover but if you need any service info then let me have an email and I can send it to you.
Jem
It turned out to be the thermal fuse on the exhaust duct. Thank you for the info and all that replied . It’s the first time i came across one of these dryers.
Micky 32
ParticipantThanks Jem. The pulleys and belt all intact and lever switch not activated. No it’s totally silent no humming etc. i’ll check that thermal fuse over the weekend.
Micky 32
ParticipantThanks Dave will check that .
Micky 32
ParticipantForgot to mention. The timer is ticking away.
Micky 32
ParticipantNo. It doesn’t attempt to turn. All belts ok and turns freely by hand.
Micky 32
ParticipantThanks Dave for the reply. The drum doesn’t actually turn. You hear some fans starting up and about 10 seconds later the error comes up.
Micky 32
ParticipantReplaced the diodes on both machines and they both sprung back to life.
Micky 32
ParticipantDiode number i used STPS2H100
Micky 32
ParticipantYep put a 2a one instead of the 1a .
