bryan-206
Viewing 15 posts - 1 through 15 (of 104 total)
  • in reply to: Candy heat pump T/D #474041
    bryan-206
    If it gets warm but you get no water I’m afraid its got no gas. Dead in the water. Claim under the parts warranty.
    in reply to: Removal of ice maker from Samsung RSH5UBMH #460557
    bryan-206
    Removing the ice-maker will cause the appliance to throw an error. If not straight away it will at power up or in case of power cut.
    in reply to: Miele KFN12924SD warm fridge #452554
    bryan-206
    Re: Miele KFN12924SD warm fridge
    Depending on the age of the appliance the fault may actually be with the the freezer. If the freezer is unable to reach the required temp the fridge will be shut down and all efforts thrown into the freezer. You will need either a Liebherr or a Miele engineer as the appliance is manufactured by Liebherr.
    in reply to: Samsung RSH1DBRS fault #453403
    bryan-206
    Re: Samsung RSH1DBRS fault
    Also the fault would only display in event of engineer intervention or a power cut. Nothing to do with power outage.
    in reply to: Samsung RSH1DBRS fault #453402
    bryan-206
    Da32-00006u used to be part number. Press and hold top left and middle right buttons to bypass and get up and running. The sensor does need replacing though.
    in reply to: Fault finding Russell Hobbs rh1247 #386495
    bryan-206
    Re: Fault finding Russell Hobbs rh1247
    Once machine is full it will be expecting motor action. If this does not happen it will shut down and drain. Some of these have very tight wiring at the front and the motors become unplugged.
    Sent from mars
    in reply to: Haus dishwasher won’t fill #386457
    bryan-206
    Re: Haus dishwasher won’t fill
    Humming is most likely drain pump rather than fill. Every cycle will drain for a min or 2 before filling begins. Does it have any water in the bottom? Did you remove the blank off from your sink waste?
    Sent from mars
    in reply to: Hotpoint WDD960 drying temperature #365467
    bryan-206
    Re: Hotpoint WDD960 drying temperature
    Filter at rear of heater unit tends to block on these. Results in low flow past the heater. Usually throws an error due to over heating.
    Sent from mars
    in reply to: Saumsung fridge freezer puzzle #384510
    bryan-206
    Re: Saumsung fridge freezer puzzle
    Need to be checking that the heaters actually come on to defrost the evaporators. If the unit does not defrost itself as it should it will not switch back on. Unplug and restart it will be ok for one cycle then shut off again. PCbs do not fail often. Sensors and thermal fuses are common. Heaters also known to fail. Have never seen a compressor fail on one of these.
    Sent from mars
    in reply to: Servis fridge freezer thermostat identification #384351
    bryan-206
    Re: Servis fridge freezer thermostat identification
    Assuming your capillary goes into the fridge this item will be compatible. Or fit a vt9 or k59. But you will need to know your machines wiring for this
    Sent from mars
    in reply to: trouble understanding the advanced search #384247
    bryan-206
    Re: trouble understanding the advanced search
    That symbol on iPhone is accessed by hitting the .?123 button then #+= button you’ll then see it. Not sure about other handsets
    Sent from mars
    in reply to: Zanussi FJDR bearing change – removing pulley #383888
    bryan-206
    Re: Zanussi FJDR bearing change – removing pulley
    You have stripped the machine why not just replace the bearings. If they fail quickly you can consider replacing the shaft and bearings next time or scrap it. Only gonna cost a tenner and some time. Make sure to glue the seal into the tub and grease the sealing lip. Also replace the tub seal between two half a or silicon works well to ensure a good seal
    Sent from mars
    in reply to: indesit slimline dishwasher #274559
    bryan-206
    Re: indesit slimline dishwasher
    Could be the PCb is supplying more than the 12 volts required to operate the relay. Or these relays aren’t man enough for the job they do…..
    Sent from mars
    in reply to: Hoover Condensor Dryer Leaking #384340
    bryan-206
    Re: Hoover Condensor Dryer Leaking
    I’d say as above that lack of ventilation is causing excess steam to condense in places other than the condenser. Test it in an open gap with plenty of ventilation.
    Sent from mars
    in reply to: rangemaster 8090 no power #384359
    bryan-206
    Re: rangemaster 8090 no power
    What makes you say the neutral is live? A shirt circuit would blow the fuse……
    Sent from mars
