Tony_EMW
ParticipantRe: Hotpoint WF860P
They don’t need programming. We stock them at £34.90+vat http://www.emwelec.co.uk
Tony_EMW
ParticipantRe: EMW issues
It’s always disappointing when our service is criticised, especially as we work so hard to ensure that repairs and orders are turned around same-day. We do try to repair as many boards as possible but only take on a new module when we have thoroughly researched it and of course have the test rig built. It is always best to check with us before sending odd modules but at least we make no charge for the return postage when customers send us modules that we do not repair. Our telephone line is generally answered between 9am-4.30pm with an answering machine taking orders out of hours. I can also be contacted on 0773 012 0672 for additional technical enquiries but preferably not for straightforward orders which should be directed to our normal 0115 9652118 line. If any customers are not sure if we repair a board, check with our website http://www.emwelec.co.uk or call us on 0115 9652118. Tony EMW
Tony_EMW
ParticipantRe: Hotpoint WT960 Stuck on Test
More often than not a mod fault. This is the Mk6 in stock at £44.90+vat http://www.emwelec.co.uk
Tony_EMW
ParticipantRe: Lux EW12001 no spin
I realise it’s all too late now but this is the no. 1 classic fault on the 513296 / 513316 timer/mod unit – clicks off the spin.
Tony_EMW
ParticipantRe: Indesit WIA111 stuck on cycle
Faulty module – in stock at £44.90+vat inc post & ready programmed. http://www.emwelec.co.uk
Tony_EMW
ParticipantRe: hotpoint wd860 display
We stock it at £29.90+vat inc post http://www.emwelec.co.uk Changing resistors wouldn’t fix these ! It’s the LEDS that burn out
Tony_EMW
ParticipantRe: Hotpoint 1603557 module
No. It can be configured for h&c or just cold. The circuitry is there on all boards for all the valves. The label just indicates the way it has been set up at the factory. Tony
Tony_EMW
ParticipantRe: Indesit WIE167. F03
Very common board fault – in stock at £44.90+vat 0115 9652118
Tony_EMW
ParticipantRe: Hotpoint stuck in spin.
Careful with this one. Heater faults also cause these boards to stall at different postions, even on spin. On digital display machines, they often count down to 1 minute and stay there. Change the heater and they work ok.
Tony_EMW
ParticipantRe: hotpoint bwd129
If you get really stuck, send it to us for a same-day test (include a note of the fault) for £5+vat inc return post. Could be a welded heater relay or corrupted chip. Tony http://www.emwelec.co.uk
Tony_EMW
ParticipantRe: indesit wi101
In stock, ready programmed – £39.90+vat inc post http://www.emwelec.co.uk
Tony_EMW
ParticipantRe: Hotpoint FEW12 Door locked light flashing
This is a classic module and interlock problem Chanege both and away it will go. We stock the module at £39.90+vat 01159652118
Tony_EMW
ParticipantRe: Servis M0331blk
Call us on 0115 9652118 with the 9 digit number from the mod that starts with 546…. Price is £39.90+vat if it’s a stock item
Tony_EMW
ParticipantRe: Hotpoint WD440 Power Module Situation
Madness !! Just order from us and we send you the correct board, eprom fitted, eprom programmed, same-day ! £44.90+vat inc post ready to go and you can send it back if you mis-diagnose for £5+vat. Are you sure you guys really want to mess around with eproms, smartcards, smartcard readers, extra cost and delays ? Tony http://www.emwelec.co.uk
Tony_EMW
ParticipantRe: All flashing HOTPOINT WF540PB
Correct. Main board fault.
